Antenna mast
Old Dec 1, 2012 | 02:55 PM
Docmace's Avatar
Default Antenna mast
Bent my antenna last night. I am trying to remove the old mast. Ive got the retaining nut off but the mast will not pull out. I get it fully extended but then I get a hard stop and it won't pull any further. Am I missing something?
Old Dec 1, 2012 | 03:39 PM
JTsmks's Avatar
Docmace, if you add what year XJS you have in your sig/tag it would be helpful. Not sure if all varients used the same antenna.
Old Dec 1, 2012 | 04:04 PM
Docmace's Avatar
Just added it. It is a '95 2+2, 4.0
Old Dec 2, 2012 | 04:32 AM
Per's Avatar
Per
If you have a Hirschman antenna with a serrated nylon wire the mast is a Jag spare part, and inexpensive too. It says Hirschman on the plastic cover. Switch on the ignition, hold/pull on the mast. Keep holding and have an assistant switch off the ignition. Once it has stopped trying to pull down the mast on with the ignition again and pull. Repeat until mast with toothed fibre wire is out.
Old Dec 2, 2012 | 04:56 AM
Premier1one's Avatar
sometimes the metal sleeve at the top gets corroded and needs to be removed before you install the replacement (I read that on my replacement mast installation instructions I got on ebay)
Old Dec 8, 2012 | 06:57 PM
macdoesit's Avatar
Banned
New Jag owner,I don't know squat. Does antenna go up and down when radio turned off on? My antenna stays up thought maybe manual but can't lower by hand
Old Dec 9, 2012 | 01:53 AM
Greg in France's Avatar
There should be a delay relay that keeps the aerial up for about 20 seconds after the radio is switched off, and then it comes down. This relay needs to be earthed to work properly, and it may be that it is not?
Greg
Old Dec 9, 2012 | 02:06 AM
Also check the fuse.
Several threads across all the model sections on the forum from members infuriated with the automatic aerial raise/lower. Some pull the fuse to stop it raising at all; others to keep it permanently raised.
Old Dec 11, 2012 | 11:00 AM
mrtalkradio's Avatar
There is a little rubber belt within those units, if it's broken no uppy or downy.
Old Mar 9, 2013 | 12:09 AM
dakine's Avatar
Originally Posted by GGG
+1
Where is the automatic aerial raise/lower fuse located.
Old Mar 9, 2013 | 02:53 AM
On your X308, it's in the Luggage Compartment Fuse Box which is next to the battery.
Fuse No #9 (10 amp)
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
philwarner
Jan 31, 2016 09:36 AM
Kaeghl
Sep 25, 2015 12:49 PM
