BEC9538 Door Lock Clip Workaround
Old Apr 12, 2015 | 06:25 PM
Vee's Avatar
Vee
Default BEC9538 Door Lock Clip Workaround
I was investigating a problem I was having with a door latch not wanting to snap back and along the way I noticed I had a broken clip BEC9538 NOT holding one of the two rods across the door.
I ended up buying to parts to make this work:
(1) Dorman 785-112 License Hardware Kit with #8x1/2" screws. The plastic square anchor fit into the square hole and then I hung two 3/16" nylon cable clamps from (2) Dorman 86108 Nylon Cable Clamp Assortment.
Both purchased at Advance Auto.
I am attaching a photo to show you how it works. Seems to work perfectly. I think the 1/4" clamps could work, but the 1/8" will not.
Attached Thumbnails BEC9538 Door Lock Clip Workaround-dsc00200.jpg   BEC9538 Door Lock Clip Workaround-dsc00201.jpg
Old Apr 13, 2015 | 03:44 PM
sidescrollin's Avatar
nice little fix! It is always funny to find something useful in the random section.
Old Nov 28, 2016 | 05:18 PM
malc4d's Avatar
Thank all. So as it was just the back fixing plug that was broken l went to Autozone and bought some white plastic square pushin fixings, cut the broken back part off, drilled a hole and fixed it to the trim plug with a screw. Looks almost original. Simples.....
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
jagent
Sep 12, 2015 09:10 AM
