Bleeding the cooling system
Old Apr 14, 2018 | 08:15 AM
knares's Avatar
Default Bleeding the cooling system
Hi, is there a procedure to follow when filling an empty cooling system
Like bleeders for instance
1988 V12
thanks
Old Apr 14, 2018 | 08:36 AM
Doug's Avatar
There are different opinions on what works for filling and bleeding but most owners use some variation of the same basic procedure. Here's the process I've used on V12 Jags. It's not difficult, just messy.
Elevate the front of the car about 8" and then elevate the left front another 2-3" beyond that. Set the climate control for max heat so the heater valve opens.
Remove the bleeder plug from the left radiator tank. You'll see an access hole in the radiator upper mounting panel. The plug is some arcane size but you'll find something in your toolbox that fits.
Remove the caps from the expansion/header tank and from the filler pipe at the front of the engine....up there by the A/C compressor.
Add coolant/water to via the filler pipe until it reaches the bottom of the pipe. Start engine, set heater control to max heat. Let it run at idle until it warms up. Peek inside the filler pipe every minute or so and top up as needed.
When the engine gets warm increase the idle to about 1000-1200 rpm (a helper is helpful here...or just wedge a little something in the throttle linkage to hold it slightly open for a high idle.
Let 'er run and run. Give the upper radiator hoses a few squeezes now and again. Keep checking your coolant level in the filler pipe and top off as needed. Eventually you'll see some coolant coming out of the bleeder. That's good. Wait a while longer and (hopefully) you'll see coolant *really* pouring out of the bleeder. (How much? It's one of those "you'll know it when you see it" things..very messy)
When it's *really* pouring out of the bleeder hole, put the plug back in. Wear some gloves so you don't get scalded. If you can't get the plug back in thru all the gushing, shut off the engine and do it....but I like to leave the engine running if I can. Not worth getting burned, though.
Top off the coolant in the filler pipe...I go right to the top but some fill just to the bottom of the neck... add a quart or so to the expansion tank if you suspect it might be low, button everything up, and yer off to the races. If you've overfilled the excess will be pushed into the atmospheric tank mounted inside the fenderwell. If you've *really* overfilled the excess will exit the atmospheric tank and end up on the ground.
Lower the car and clean the driveway :-)
Old Apr 14, 2018 | 08:48 AM
Following Doug, as usual, haha.
My method.
Bleeding the V12 cooling system.pdf
Old Apr 14, 2018 | 09:09 AM
knares's Avatar
thanks guysI was a bit reluctant to ask such a question but now I am very glad I did Thanks a lot
Old Apr 14, 2018 | 09:37 AM
Greg in France's Avatar
Just one extra point, have the aircon on defrost while you are doing this. It helps get the heater core filled. I also am a strong believer in having the front of the car pointing up a slope a bit too.
Old Apr 14, 2018 | 09:44 AM
Doug's Avatar
Don't be reluctant to ask. We don't bite . Everyone here loves old Jags and is willing to share info and experiences.
I've been running older Jags for 20+ years and *still* learn something new from others almost every day.....sometimes before I've finished my first cuppa coffee in the morning!
Old Apr 14, 2018 | 01:17 PM
sidescrollin's Avatar
If it makes you feel any better, my car leaks at the top hat seals and I regularly have to refill it (every 2-3 months). I never bleed the system from the banjo and it always cools just fine.
Not at all saying there is no benefit or reason to do it properly, just trying to let you know that you don't need to worry. Just because there is a very specific method does not mean its the only way that will work. If you system doesn't leak, by all means spend the extra few minutes to bleed it out.
Old Apr 15, 2018 | 09:34 PM
knares's Avatar
thanks guys
Old Apr 17, 2018 | 10:54 PM
knares's Avatar
This car had an small engine fire at the rear of the engine, it burned some wires.So the leci could get to them, I removed the fuel rail and what I thought was the coolant crossover pipe at the rear of the engine.When I removed the pipe I noticed that there was no water thereI have reassembled the parts, but I thought I would make sure water was getting to the crossover pipeIts notI tried blowing in to the filler pipe (lung pressure) but no luckIs this crossover pipe a water pipe, it dose have a T and a small pipe going some where If it isn’t, what is it and what is the small pipe for.
thanks
Old Apr 17, 2018 | 10:55 PM
knares's Avatar
no water from the blue hose or pipe
Old Apr 17, 2018 | 11:07 PM
Doug's Avatar
The 1" diameter pipe at the rear of the engine is a vacuum valance pipe. Does not have coolant flowing through it. The small hose attached is the vacuum supply of for the ECU in the boot
Old Apr 18, 2018 | 04:41 AM
knares's Avatar
Originally Posted by Doug
The 1" diameter pipe at the rear of the engine is a vacuum valance pipe. Does not have coolant flowing through it/ The small hoses attached is the vacuum supply of for the ECU in the boot
The plot thickens
thanks
Old Apr 18, 2018 | 06:06 AM
Some Day, Some Day's Avatar
Why would the ECU need vacuum?
Old Apr 18, 2018 | 06:52 AM
The vacuum in the intake manifold is a proxy for the extent of demand for power from and load upon the engine (ie low vacuum=throttles wide open=need power; high vacuum=throttle closed=not much power required). This, together with the throttle position sensor give inputs to the ECU which enable the pre-programmed ECU chip to decide how much fuel to squirt into the cylinders. At least, that is my layperson's understanding.
Old Apr 18, 2018 | 07:12 AM
So the vacuum line doesn't actually go all the way to the ECU in the rear, but to a sensor? That makes sense.
(I would totally understand if that were the case--the bit about the "vacuum supply" made me wonder if there was some reason the ECU itself needed vacuum, which would puzzle me.)
Old Apr 18, 2018 | 07:22 AM
The vac line goes ALL the way to the ECU, then through the casing, to a smaller hose inside, and terminates at a Sensor on the circuit board.
Less vac = more fuel
More vac = less fuel, and then, as Greg said, things like engine temp, throttle capstan position, all do what they do to run the engine.
Dinosaur stuff by todays standards, but this is all 1960's technology, just fine tuned a tad for the HE, and a tad mire for the Mareli beasts.
Those snaps also show the throttle spindle pivot bush AWOL, and that engine will NEVER run right without those 2 bushes, one each side, being in place and in good shape.
Old Apr 18, 2018 | 07:36 AM
Blimey. All that way? Seems like it would be way more sensible to have the sensor near the thing being sensed, like the other parts of the engine, but then I'm not a Jaguar engineer.
Old Apr 18, 2018 | 07:40 AM
Drink more, much more, it will all become as clear as mud.
It is all this "normal" stuff that confuses the masses, and keeps the prices DOWN, so we can afford them, simple as the cars themselves.
Old Apr 18, 2018 | 07:54 AM
Ah, that's what I'm doing wrong. I don't generally drink anything stronger than tea....
Incidentally, prices are very much not down over here in Japan. The most expensive currently on sale is this US$42,000 (plus on-road costs) convertible, and the average asking price is US$24,391 (plus on-road costs). I think someone must have been blabbing....
Old Apr 18, 2018 | 08:13 AM
knares's Avatar
noted,
thanks
