Boot reinforcement panel
Old Mar 1, 2023 | 06:12 AM
rgp's Avatar
rgp
Default Boot reinforcement panel
Can someone look on there post 88 model and rell me what holds this panel to the rear wing.
s​​​elf tapers or nuts and bolts The parts book is not helpful.
Old Mar 11, 2023 | 05:30 AM
Brake buster's Avatar
its nuts and spring washers to hold this trim to welded threaded studs on the underside of the upper inside rear buttress gutter,
BB
Old Mar 11, 2023 | 09:31 AM
Greg in France's Avatar
Erroneous reply deleted
Old Mar 11, 2023 | 06:31 PM
sanchez's Avatar
On my 88 XJS there are studs on the underside of the rear fender. See attached photo
studs shown here. I removed the nut and spring washer to show you.
Old Mar 11, 2023 | 10:06 PM
baxtor's Avatar
Early were screws and nuts and later were studs and nuts, not sure when change occured.
Old Mar 11, 2023 | 11:52 PM
My 1985 had scews and nuts, which I changed for stainless allen key headed bolts and nuts.
Old Mar 12, 2023 | 05:52 AM
rgp's Avatar
rgp
THANKS ALL
The reason I ask is it worked out cheaper to buy 2 good 2nd hand panels than to get a second hand earlier courtesy Hella lamp. Mine were self tapped in place. The parts book has them as M5 nuts and plastic covers. I have the covers so just the nuts to get.
Bob Hornby
Jun 4, 2021 07:39 PM
rgp
Jul 19, 2020 01:23 PM
Jay Whitbread
May 13, 2018 05:47 AM
romroc
Jun 26, 2017 06:07 PM
