Brake Hose Lock Nuts where can I buy these in the UK
Old Oct 26, 2016 | 06:05 AM
orangeblossom's Avatar
Default Brake Hose Lock Nuts where can I buy these in the UK
Although I can buy Brake Pipes, nobody seems to be able to supply the Lock Nuts to clamp the Brake Hose in place where it passes through the Body Work.
Even the Thread looks non-standard
Any Ideas?
Old Oct 26, 2016 | 06:32 AM
Daim's Avatar
I think I read somewhere that they are simple metric threads...
Old Oct 26, 2016 | 06:38 AM
ptjs1's Avatar
OB,
If its the washers and locknuts for the front flexis, then it's part number C41712 for the nut and WF10001J for the washer. Nuts are only about 50p from Jaguar or pattern parts 30p from SNG Barratts or David Manners etc. They are M10 but I THINK a fine 1.0 thread.
Hope that helps
Paul
Old Oct 26, 2016 | 07:06 AM
Greg in France's Avatar
OB
If you mean the thin nut that does up from the engine side to fix the male end of the flexible into the body metalwork, I am pretty sure it is Metric Fine Thread. It looks like UNF but I do not think it is.
Greg
Old Oct 26, 2016 | 11:57 AM
OB
Greg
Hi Greg
I think you are 'bang on' with that, as I seem to remember that I had this problem last time.
For some strange reason they are not supplied with the new Brake Pipes, even though its almost certain that you are going to need them.
Old Oct 26, 2016 | 12:02 PM
Originally Posted by ptjs1
OB,
Hope that helps
Paul
Hi Paul
Yes, they are the ones I need but I just cannot understand why they don't supply them with the New Brake Pipes.
Old Oct 27, 2016 | 02:03 AM
baxtor's Avatar
Originally Posted by orangeblossom
Hi Paul
That's just cheap on the part of the manufacturer. I will note mine came with nuts whenever l have needed them.
