Brake light failed system
Old Aug 16, 2023 | 05:48 PM
Patrick 1989 XJS's Avatar
Default Brake light failed system
I replaced the steering column assembly including turn signal with cruise control, wiper arm, moved some lighting circuits and replace the headlight relay system with new latching relay and additional relay for to have four head lamps on at the same time.
The new headlamps work the turn signal works until I step on the brake pedal then it blows circuit #5 in the main fuse box. Can I remove some load from fuse #5 or is there something missing in the wiring? The new wiper I purchased would stop at the bottom of screen. Now the wiper stops randomly on the wind screen liem the old one.
Help!
hijk
Jul 11, 2020 11:24 PM
smillerncl
Mar 8, 2017 02:01 PM
marvin.d.miller
Jan 24, 2015 01:49 PM
Jimmysea
Dec 14, 2014 08:00 PM
Jimmysea
Dec 1, 2014 07:22 PM
