Brake lights not working XJS
Old Dec 18, 2021 | 12:53 PM
sd63141's Avatar
Default Brake lights not working XJS
My two main brake lights stopped working, but the middle one on top of the trunk is still operational. Turn signal and running lights work fine. I also noticed that the hazard lights do not come on when I push the button, don’t know if that’s related. Any help would be greatly appreciated thank you.
- Scott
1992 XJS V12
Old Dec 18, 2021 | 02:24 PM
mghirsch's Avatar
Get a wiring diagram and look for a common point.
BTW, did you check to see if the bulbs are good?
Old Dec 18, 2021 | 03:06 PM
petemohr's Avatar
Here's the diagram. Nothing common between the hazard flasher and the brake lights. Looks like the only common thing for the brake lights is the bulb failure unit.
File Type: pdf
Old Dec 20, 2021 | 04:51 AM
egovreau's Avatar
This is most likely the cause. It was for me. Unfortunately, they're NLA, so you'll need to source a used one, or New, Old stock.
Or you can try and either bypass, or build a custom bulb failure sensor.
Old Dec 21, 2021 | 12:55 PM
sd63141's Avatar
thanks for the info and bulbs are good
Old Jan 7, 2022 | 03:10 PM
sd63141's Avatar
Default Update
The bulb failure relay/unit did the trick. Got it replaced and it’s working as published! Thanks for the help.
Scott,
1992 XJS V12
gabbycat
Oct 14, 2021 11:37 AM
wimpertjo
Jun 2, 2021 08:52 PM
tony3
Apr 6, 2018 04:49 PM
coastaljag98
Oct 15, 2012 10:19 PM
perfectphoto
Oct 27, 2011 01:50 PM
