Brake pedal fades
Old Feb 10, 2024 | 12:57 PM
JigJag's Avatar
Default Brake pedal fades
So, I bled this system well, and I have a rock hard pedal ( engine off ) that slowly fades down. 17 seconds of hard pressure and it will bottom out. engine on, decent pedal stiffness and more rapid fading.
Master cylinder seals are leaking, correct?
edit: I should add that no leaks were found anywhere in the system.
Old Feb 10, 2024 | 01:14 PM
ptjs1's Avatar
JigJag,
You haven't said what year you have? Does it have ABS?
Paul
Old Feb 10, 2024 | 06:51 PM
JigJag's Avatar
Sorry, that used to be in my signature.
‘86 no ABS.
Old Feb 11, 2024 | 02:00 AM
Greg in France's Avatar
Definitely the master cylinder if no leaks in the system.
Old Feb 11, 2024 | 11:38 AM
kansanbrit's Avatar
How often do you brake for 17 seconds ? Why would you even test it like that? Could be lots of things.
Old Feb 14, 2024 | 08:53 AM
JigJag's Avatar
Perhaps I wasn’t clear. I am not driving the car. I am testing the braking system. If I am at a stop light I’d like for the brakes to operate indefinitely. I frequently need them to hold the vehicle stationary.
Civicalized
XJ40 ( XJ81 )
Jul 29, 2022 01:00 AM
Xdevo1973
XJ40 ( XJ81 )
Oct 14, 2017 12:15 AM
al_roethlisberger
Aug 20, 2015 06:18 AM
plums
Jul 8, 2015 05:18 AM
mava89
XJ40 ( XJ81 )
Aug 31, 2010 03:54 AM
