Butterfly adjustment
Old Apr 15, 2018 | 10:59 AM
rgp's Avatar
rgp
Default Butterfly adjustment
is there a better way of adjusting the butterfly's than using a 4 thou feller gauge which I don't have spot on,
Old Apr 15, 2018 | 11:18 AM
Daim's Avatar
Nope. That is the only precise way of doing it...
Old Apr 15, 2018 | 01:05 PM
rgp's Avatar
rgp
I have also been told that a dial gauge may be most accurate, also Haynes has it down at 4 th. but jag lovers states 2 for the h.e which one is correct?
Old Apr 15, 2018 | 03:56 PM
Vtjaguarlover's Avatar
For the 5.3 V12 I went with .002 as any more raises the idle speed
Old Apr 15, 2018 | 06:41 PM
Doug's Avatar
I always go with .002"
Old Apr 16, 2018 | 06:11 PM
JigJag's Avatar
Well, I've been looking for wire gauges. They would be a bit more accurate than a strip gauge as they would read only at the point they are inserted. No luck yet. Should be .002" for H.E.s.
Old Apr 16, 2018 | 10:30 PM
user 652867429824's Avatar
I used a flat feeler gauge, the butterfly should be set at .002 for the HE
osyris
Aug 4, 2023 06:39 PM
Neil1664
Nov 2, 2015 12:26 PM
Blackbutterfli
Mar 15, 2015 01:09 AM
rsigue
Jun 27, 2012 09:12 AM
Goldlion
Mar 5, 2011 07:21 AM
