Castrol Systhetic brake fluid ok?
Old Apr 28, 2014 | 12:46 PM
mkinn's Avatar
Default Castrol Systhetic brake fluid ok?
I just replaced 2 rear calipers, pads, e-brake pads, and the ABS pump.
I'm ready to bleed it, but wanted to ask if synthetic brake fluid is ok?
Thanks!
Old Apr 28, 2014 | 01:48 PM
Doug's Avatar
All brake fluid is synthetic....which makes the labeling on the bottles a little confusing.
You should be fine with any conventional (that is, non-silicone) 'Dot 4' brake fluid
If you happen to be looking at a bottle of 'Castrol GT/LMA' brake fluid, that should do the trick
hoodun
Oct 2, 2015 10:13 PM
JeffinSwitz
Sep 16, 2015 01:44 PM
mrplow58
Sep 15, 2015 09:58 PM
Richard_gib
Sep 12, 2015 07:08 PM
trebor12
UK & Eire
Sep 12, 2015 12:21 PM
