CD Player
Old Jul 19, 2017 | 08:52 AM
malc4d's Avatar
Default CD Player
Someone posted a thread about updating the CD player with a newer Alpine version.
Anyone know where that is ? yes l have searched.....
Old Jul 19, 2017 | 05:48 PM
warrjon's Avatar
Is that the boot mount stacker?
Does your car already have a boot mounted CD? If so why do you want to replace it?
Old Jul 19, 2017 | 10:33 PM
malc4d's Avatar
The original is just a cd player and only plays cd files. The one l read here about was an updated version using the same cables but could play all types of cd discs like mp3 etc. Increases the listening pleasure lol
Old Jul 19, 2017 | 11:12 PM
warrjon's Avatar
The Alpine CHA-S634 has CD, CD-R/RW and MP3 capability, if your head unit supports Ai-NET then it's a plug and play install. The manual for your head unit should say if it's Ai-NET, if not I'm sure Google will know.
Old Jul 20, 2017 | 07:04 AM
malc4d's Avatar
Thanks for the info. I found that unit but I think the cable in the car is not Ai-net, Its the round din plug. The thread had the number of the player that was a direct replacement.
Old Jul 20, 2017 | 10:11 AM
Brg XJS's Avatar
I am looking for a new cd player also. Can you supply the number of the player that is a direct replacement please? Thanks!
Old Jul 20, 2017 | 05:20 PM
warrjon's Avatar
Ok the din plug is mini-bus. I took a look at the specification for the CHA-S634 and it is m-bus compatible, there is a switch that selects AI-net or mini-bus control. So it should work and you will need the AI-net to din cable
here is a link to the manual
http://download.alpine.com.au/Produc...4/CHA-S634.PDF
and cable
http://www.discountcarstereo.com/ALP-Ai-M15.html
Old Jul 20, 2017 | 09:53 PM
malc4d's Avatar
Its the original 1991 facelift radio that was made by Alpine and l have an alpine 6 CD changer connected to the original boot cable, that's the same as the Jag one. I'm not sure what Mbus means. Is that what the used in the 90's ?
Old Jul 21, 2017 | 03:55 AM
warrjon's Avatar
M-bus is the DIN plug
Old Jul 21, 2017 | 08:36 AM
Rob519's Avatar
Default CD player
Hi Malc4d
assuming head unit is the same as mine (suspect it will be) you want model Alpine CHM-S630.
I have it in my 1994 facelift and it works fine. Also can play back mp3, cd-r as well as normal CD's
Regards
Rob
