center dash vent modification
Old Jan 27, 2015 | 07:41 AM
Brake buster's Avatar
Default center dash vent modification
as we all know, the XJS has a bit of an asthmatic ventilation system , and this isn't helped by the huge vent in the middle of the dash ,
831 by MyPix on Talk Photography
it has been a known upgrade to fit the later facelift vent and or a modified one from a 40 or something, the facelift vent if you can get one is £100 or more though , so not a lot bother with carrying out this minor work
I had a slightly different idea ,
why not blank off the middle fixed section and force what little air there is to the two adjustable side vents of the outlet
with this in mind I purchased a good used centre vent for the XJS , and proceeded to chop it up :shock:
but I did have a plan , I bent some sheet tin , and formed a ' pocket ' and then covered it in period looking flock that has an adhesive backing , and ended up with this
824 by MyPix on Talk Photography
not bad if I say so myself
I then went to my car and removed my perfectly sound original vent, this is easily done by dropping the glove box door and gently prying off the walnut trim with a suitable tool , and
then removed the vent which is just a push fit
832 by MyPix on Talk Photography
and then installed my modified vent grille , and put the walnut trim back in place
833 by MyPix on Talk Photography
I still have my original vent should I wish to go back , but now have somewhere other than the ski slope to put change or keys etc , slightly too small for my iPhone though :roll:
and as for the extra air ?? , well , its a little better , lmfao :mrgreen:
BB
Old Jan 27, 2015 | 09:22 AM
Flint Ironstag's Avatar
How about some more interior pics, please! Always loved mulberry, and that Alpine looks like it was made to go there. Nice.
Old Jan 27, 2015 | 09:35 AM
just for you.......lol
1820 by MyPix on Talk Photography
original white over Mulberry car , double stitched all leather with ' wine red ' carpets
BB
Old Jan 27, 2015 | 05:39 PM
Sharp combination!
Old Jan 29, 2015 | 05:49 PM
kenatofc's Avatar
That's really cool... What is with the single handle Gear shift.... I have the double one. Does it screw onto the shaft of the shift column ??
Old Jan 30, 2015 | 01:17 AM
the gear shifter knob is a Jaguarsport upgrade ( XJR-s or TWR ) , and can only be fitted to a threaded shifter stick
your shifter has the ' t-bar ' shifter by the sounds of it , this can be cut and threaded, or a genuine Jaguar replacement fitted.....
thread size on mine is 8mm
BB
Old Jan 30, 2015 | 03:28 AM
Also never seen the central / horizontal part of the steering wheel (where the horn pads are) in anything other than black. Is that aftermarket?
Old Feb 3, 2015 | 01:55 PM
Safari's Avatar
Here is my temporary, down-and-dirty center vent blocker;
Later, when I have time, I will make a black plate with a Leaper and mount it flush with the side vents.
Mark
Old Feb 4, 2015 | 02:05 PM
tokyodon's Avatar
Looks like a space for mini gauges if there is a need. I do like the Leaper idea though.
danke
Mar 3, 2016 10:57 AM
perezal
Dec 29, 2015 08:48 PM
PinnacleWax
Detailing / Car care
Sep 16, 2015 10:28 AM
MI-FType
Sep 13, 2015 11:26 PM
1964Daimler
Sep 9, 2015 11:28 AM
