Check Engine Light
Old Dec 19, 2011 | 05:34 PM
mrtalkradio's Avatar
Default Check Engine Light
I have a FF36, I read what it means, but I haven't a clue where to begin and diagnose the issue. Any guidance here would be appreciated as always.
Old Dec 19, 2011 | 07:12 PM
warrjon's Avatar
FF36 is a fuel injection fault in the B bank. This code is set when the maximum fueling correction is applied either high or low. It is part of the closed loop including the O2 sensor. I would start there (o2 sensor). Check the connector and wiring for faults, you could even swap the sensors from one side to the other if you get an FF34 A bank then the sensor is faulty.
cheers
Warren
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
