Checking transmission fluid cold??
Old Mar 4, 2015 | 10:28 PM
paulyling's Avatar
Default Checking transmission fluid cold??
Hi Guys
I was taught to check transmission fluid when the engine is up to normal running temps, however last time I checked mine, I noticed that on one side of the dipstick it says HOT and the other side COLD.
Am I just a "dipstick" or can you actually check it cold using the other side as a gauge?
Old Mar 4, 2015 | 10:44 PM
Doug's Avatar
The 'cold' side never gives a good reading IMHO. It's useful, though, to determine if you have enough fluid to drive the car 10-15 miles so a proper 'hot' reading can be taken !
Old Mar 5, 2015 | 12:47 AM
Ezrider's Avatar
as said cold is a general reference hot is a accurate check.
Old Mar 5, 2015 | 02:06 AM
paulyling's Avatar
Cool guys. Thanks for clarifying that. It makes alot more sense now.
Old Mar 5, 2015 | 02:17 AM
o1xjr's Avatar
I was once told the cold gauge is a guide for filling when a service has been done, as Doug said above to be able to drive the car to get an accurate reading.
Old Mar 5, 2015 | 02:23 AM
paulyling's Avatar
Cheers Clarke
Yeah I only noticed it last time I was home and thought WTH? I always check a few times when I'm home after we found it pretty low that time. But yeah I guess as a rough guide at least you know something is in there and it's not bone dry.
Old Mar 5, 2015 | 08:49 AM
XJSFan's Avatar
After I do a ATF drain and fill on any vehicle, I always check it hot and also check it for a few days after. I would think that if the car has been driven for months and the ATF is at the cold reading or a little higher, then the fluid level is fine.
Old Mar 5, 2015 | 09:24 AM
JTsmks's Avatar
Originally Posted by paulyling
Cheers Clarke Yeah I only noticed it last time I was home and thought WTH? I always check a few times when I'm home after we found it pretty low that time. But yeah I guess as a rough guide at least you know something is in there and it's not bone dry.
Paul, you know how many times I've checked mine in 6 years? Once! Quit being neurotic and enjoy the car! If it drives fine and shifts fine, it's fine. You're going to wear the dipstick out!😃
Safari's Avatar
I agree with most of the responses here that the Hot check is the most accurate and is the one to be relied on.
One thing not mentioned about the Cold check is that during service it does two things;
1. Ensure there is enough fluid for initial start-up.
2. Prevent overfilling.
Some transmissions can be damaged if too much fluid is installed.
Filling to the Cold line prevents overfilling and should indicate a correct Hot reading once the fluid is warm and has expanded.
Mark
Old Mar 5, 2015 | 05:48 PM
paulyling's Avatar
Thanks Mark.
That seems pretty logical. I didn't know that
SD96XJ6L
Jan 12, 2022 04:30 AM
KarimPA
Sep 12, 2015 08:15 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
KarimPA
Sep 3, 2015 07:32 PM
