Clutch pedal spring?
Old Oct 2, 2020 | 02:12 PM
Segfault's Avatar
Default Clutch pedal spring?
I had to remove my master cylinder for overhaul and after I put it back I found a little spring on the floor. Where the heck it came from, looks broken, too.
Old Oct 2, 2020 | 05:17 PM
jal1234's Avatar
Looks like a brake pedal return spring. Did you pull the pivot pin on the pedal in the process of changing the master?
Old Oct 3, 2020 | 05:02 PM
Segfault's Avatar
That's what is confusing, I did not pull the pivot pin. Anyhow, the clutch pedal feels not the same, so it must have been from clutch pedal. Methinks the assembly is from 1988- manual transmission car (inline 6). I wonder if this spring is sold somewhere ...
Old Oct 3, 2020 | 05:26 PM
baxtor's Avatar
Not local to you but you could try here. As you can see l think your spring is missing the tails.
Old Oct 4, 2020 | 08:08 AM
Segfault's Avatar
Thanks, with little detective work I started at Jagdaim and reached Terry's part C25506 ... looks similar.
iansane
16
Aug 20, 2020 04:36 PM
bobanddoug
Jul 20, 2017 04:17 PM
disguay
May 30, 2012 02:44 PM
SpartanX
Mar 11, 2012 02:01 PM
gary Cox
E type ( XK-E )
Dec 13, 2011 08:59 PM
