Cold start high RPMs
Old 12-22-2018, 08:27 AM
JigJag's Avatar
Also temporarily seal the overrun valve intakes in the front of both air filter boxes to check that they are not the leaky bit.
Greg in France (12-22-2018)
Old 11-04-2023, 02:14 PM
bavila's Avatar
Default PCV
Originally Posted by leo_denmark
Throttle position Sensor. It's a potentiometer placed in the capstan tower sending a voltage signal to the ECU. 0,32V is idle, 5V'ish is fully open
I had a fair amount of air coming throug the crankcase vent valve connected on front of LH airbox. Blocking that lowered my RPM 150-200 (warm). I modified it by preloading the spring a bit more, that was the final thing that made my RPM settle correctly.
BR Leo
Hello Leo, I also have high revolutions when cold (1200) and when hot, close to 1000. I observed that the crankcase breather valve (PCV) allows air to pass at idle. It's right? If I lock it, it also drops to 750 rpm. How did you go about preloading the valve spring? Thank you so much!
Z07Brandon
11-20-2018 12:43 AM
bvxtype
11-09-2018 02:50 AM
rufeo690
11-08-2018 08:40 PM
Roy Curtis
11-05-2018 05:26 PM
steve
11-03-2018 04:47 PM
Quick Reply: Cold start high RPMs
