Common Parasitic Draw Causes
Old Nov 27, 2024 | 03:08 PM
MrAndersonGCC's Avatar
Default Common Parasitic Draw Causes
I definitely have a parasitic draw somewhere; brand new battery is dead after a few days of sitting.
I know I can go around and unplug various things until the draw stops, but that would take a while (unplug something, then wait a few hours and test the battery voltage again, repeat until voltage doesn't drop).
To potentially save some time, I thought I'd ask: Is there a particularly common cause of a parasitic draw in our cars?
Old Nov 27, 2024 | 03:34 PM
AZDoug's Avatar
Do you ahve a VOM with low current ammeter?
You can check each circuit in less than 30 seconds using that.
If you get some amp or two current, that is your drain. Make sure your doors are closed so you don't pick up interior light draw.
Doug
Old Nov 27, 2024 | 03:43 PM
ptjs1's Avatar
MrAndersonGCC,
You haven't said what car you've got, as that makes a difference for likely causes.
If it's a late facelift, I'd say start with boot light and alarm system.
Paul
Old Nov 27, 2024 | 03:44 PM
Originally Posted by AZDoug;[url=tel:2804792
2804792[/url]]Do you ahve a VOM with low current ammeter?
Doug
This is the vom I have. I’m used to testing ohms and volts, but how do I test the current of a circuit? Just use the DC 10A input and put the ends on one of the glass fuses?
Originally Posted by ptjs1
MrAndersonGCC,
Paul
It’s a 1983.
Old Nov 27, 2024 | 05:52 PM
AZDoug's Avatar
DC 10A. Plug the red wire into the red circle socket..
Not sure about fusing on that meter, perhaps download the instructions and read them
Doug
Old Nov 28, 2024 | 04:31 AM
Greg in France's Avatar
Just pull each fuse in ti=urn while you measure the drain on the battery with your meter
Old Nov 28, 2024 | 10:33 AM
Originally Posted by Greg in France;[url=tel:2804922
2804922[/url]]Just pull each fuse in ti=urn while you measure the drain on the battery with your meter
Ok that makes sense, the meter will complete the circuit in place of the fuse. Thanks
Old Nov 28, 2024 | 02:56 PM
I pulled every fuse under the steering column and the five in the engine bay, measured for a current and got nothing.
Is there anywhere else I should be testing?
Old Nov 29, 2024 | 01:08 PM
I tested again, this time looking for current between the negative cable and the negative post while pulling one fuse at a time. Current read 1.65 amps. Same result, current didn’t change, held steady at 1.65. Any other ideas?
Old Nov 29, 2024 | 01:47 PM
AZDoug's Avatar
Here are a couple:
Mentally cuss out Lucas electric, to start with.
Get a wiring diagram and cuss out the guy who drew it as a wiring schematic, instead of a wiring diagram, and try to figure out where you have an unfused draw.
Get something like this and try various wires until you find the one with current.
Amazon Amazon
Amazon Amazon
Doug
Old Nov 29, 2024 | 01:59 PM
Originally Posted by AZDoug;[url=tel:2805288
2805288[/url]]Here are a couple:
https://www.amazon.com/TECPEL-CA-60-.../dp/B0753GD1C6
https://www.amazon.com/Multimeter-Re.../dp/B089778TJT.
Doug
Cussing complete. Thanks for the links Doug!
Old Nov 29, 2024 | 04:18 PM
Found it!
I recently replaced a couple relays in the trunk near the battery when I was chasing another electrical problem.
I didn't have a parasitic draw until recently so I unplugged one of the relays and the current dropped to zero. Put the old relay back on and current stayed at zero. Clearly not all 5 pin relays are the same and I chose poorly.
It was the one with the red plug:
Old Nov 29, 2024 | 05:05 PM
AZDoug's Avatar
Internal circuitry can vary on replays.
The little schematic on the side of the relay helps quite a bit, and sometimes very minor variation in the schematic, may go unnoticed unless you get a magnifying glass out. I noticed there is a relay or two that is hard to find a replacement for, but don't recall which ones they were.
Doug
axr6
Dec 22, 2022 09:35 PM
x350
Aug 26, 2021 09:16 AM
jomo
Jun 8, 2020 06:31 PM
cadvision
Nov 19, 2016 01:28 PM
lcotelaw
Jan 30, 2014 08:22 AM
