Compressor moisture mitigation.
Old Jun 18, 2021 | 07:46 PM
equiprx's Avatar
Default Compressor moisture mitigation.
Sorry to beat a dead horse, but here is where I currently stand.
After weeks of fabrication, fudging and de-leaking, I installed my 5 HP, 30 gal. oil-less compressor in my equipment shed.
I also installed an automatic drain that appears to be dripping wet after starting.
However, I’m still getting water out of the hose, into the tools.
What I was thinking lately is installing a chiller inline, between the pump and the tank.
I have several of them between 1K and 1500BTU, that are capable of freezing water.
Obviously, I don’t want to do that.
The questions I have are what temperature should I set it at?
Should it be located above or below the compressor.
Would I want to install the auto-drain at the chiller outlet?
Old Jun 28, 2021 | 05:29 PM
kansanbrit's Avatar
Why is this in an XJS forum?
Old Jun 28, 2021 | 06:06 PM
Thorsen's Avatar
What does the instruction manual recommend? My chiller isn't adjustable but holds the temp right about 35*F. That's enough to condense out most of the mositure.
Old Jun 28, 2021 | 06:20 PM
equiprx's Avatar
The reason it's on the XJS forum is as a former XJS owner I found other owners to be great sources of knowledge of all kinds.
Sorry to intrude.
Spikepaga
Jul 11, 2017 11:20 PM
Wessex
General Tech Help
Dec 29, 2015 04:40 PM
lsuneworleans
Jun 30, 2010 04:35 PM
teflondon
Jun 24, 2009 09:09 PM
