Conv.top button switch for top down, 1996 xjs
To all,
I am in the process of selling the jag as discussed a while back. Trying to make sure everything is functioning properly.
the top down button switch mounted in the emergency lever assembly is not working correctly. The button switch was bound up because I rarely put the top down. I used lubricant to loosen it up and got it to work…but again is sticking which does not indicate emergency brake engaged and therefore top won’t go down.
1. is this switch available
2. what is it called
I couldn’t seem to locate on the internet …….probably because I don’t know the proper name.
Thanks as always
Softball60/Paul
Thanks as always
Softball60/Paul
Paul,
NLA from Jaguar, and no OEM or pattern options from SNG Barratt or David Manners.
However, there are a few original on eBay, and Britishparts.co.uk seem to have a pattern option available. See here: Switch Handbrake DAC3351 | DAC3351 | British Parts
Good luck
Paul
Good luck
Paul
