Convertible Top Fluid Sensor
Old Dec 1, 2015 | 04:54 PM
TweeTwee's Avatar
Default Convertible Top Fluid Sensor
Is there a sensor in the convertible top fluid reservoir to tell it when it is out of fluid? I have a leak and am going to refill it to find it, but the motor doesn't run at all at the moment (it used to intermittently work) and I am wondering if it can sense the fluid issue.
Old Dec 1, 2015 | 07:41 PM
superchargedtr6's Avatar
No fluid sensor. But I will tell you from experience....with the wrong fluid, i.e. power steering fluid, etc., the viscosity will cause so much draw of amps, that the windows won't work properly, nor will the top go all the way up or down before the time the control unit works will cause the top and or the windows to stop. The correct fluid is so incredibly thin that it seems to pour easier than water if that is possible. Once I flushed my system, put a new seal in the pump, refilled with proper fluid, my top and windows will go fully up, or fully down in 6 seconds flat.
Old Dec 1, 2015 | 08:17 PM
TweeTwee's Avatar
Thanks! I'm looking forward to having it back working. For fluid I was going to go with Dexron III, is that not suitable? Did you get yours from Jaguar?
Old Dec 2, 2015 | 07:30 AM
ptjs1's Avatar
TweeTwee,
Don't use Dexron III. It's not at all the same. You need a fluid that is equivalent to Univis J13 Hydraulic Fluid. Equivalents are used in the aircraft industry.
Good luck
Paul
Old Dec 2, 2015 | 08:26 AM
TweeTwee's Avatar
Thanks Paul, I will get it ordered. Much appreciated.
Old Dec 2, 2015 | 04:56 PM
Jonathan-W's Avatar
I ordered this
5606 Oil Hydraulic Fluid Mil PRF 5606H 1 Qt Mil H 5606 Mil PRF 5606 with Certs | eBay
Old Dec 2, 2015 | 07:23 PM
That's what I bought. Worked perfectly. I found a bottle of Lucas stop leak in the car when I bought it, along with power steering fluid bottles. I can only presume that is what my system was full of.
Old Dec 3, 2015 | 10:38 AM
Jonathan-W's Avatar
Old Dec 3, 2015 | 04:19 PM
I bought one of of eBay for 14.95 with free shipping
Mark SF
Dec 14, 2015 11:38 PM
sklimii
Dec 11, 2015 07:08 AM
Joe Gandalf
Dec 4, 2015 05:58 PM
alanroberts50
Nov 27, 2015 08:01 PM
Bcrary3
Nov 24, 2015 07:02 PM
