Convertible Top Tension Wire
Old Dec 7, 2014 | 02:49 PM
hoodun's Avatar
Default Convertible Top Tension Wire
When I purchased my car it had no top. I put a new top on years ago with a DIY tension wire. I finally purchased an OEM tension wire.
I have an issue where it does pull down correctly on the sides. Now that I am replacing the wire I would like to remedy this. I believe they had a cut out in the canvas to keep the wire in place? Can someone check the to pon their xjs and let me know if there is a cut out?
Here is a photo of what Im dealing with (...car is being wet sanded after fresh paint in case your wondering):
Old Dec 7, 2014 | 08:59 PM
superchargedtr6's Avatar
It could be that the "lip" is bent down against the car, not allowing the tension cable to properly tuck the top under it. The tension wire actually passed through the top about there on my 89. If I remember correctly, I had to cut a small slit, and the cable went through the top as it got near its anchor points.
Old Dec 9, 2014 | 09:05 PM
hoodun's Avatar
The lip appears ok.
I'm going to try cutting a couple slits in the problem area. I can always go back.
Old Dec 10, 2014 | 09:27 AM
ptjs1's Avatar
Hoodun,
Just to let you know that you've got the riveted plates on the hood corners on the wrong sides of the car. They should be fitted so that the curved bulge of the plate points towards, and just overlaps, the end of pleated roll on the bottom of the hood.
Paul
Old Dec 11, 2014 | 07:03 PM
hoodun's Avatar
Originally Posted by ptjs1
Hoodun,
Paul
Thanks, I was wondering this when I was doing it and could not find a close up photo.
Old Dec 11, 2014 | 07:05 PM
hoodun's Avatar
I am starting to think the wire is suppose to come out at that point before going into the car. So it is actually wire touching the lip and not wire over fabric.
99xk8guy
Sep 29, 2025 10:51 PM
RoyLittle0
May 25, 2023 02:38 AM
Bowman
Sep 15, 2015 06:54 AM
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
