Coolant refill.
Old Jan 3, 2019 | 11:21 AM
brinny's Avatar
Default Coolant refill.
I have been very slowly dribbling fresh coolant into my v12 as instructed. Ive now put around 10 litres in and there are no leaks so far but I have not had any sign its gone in. i.e no gurgling noise to say that air is coming out. Does this seem right? I know it needs double that amount to fill it. Thanks
Old Jan 3, 2019 | 11:38 AM
Greg in France's Avatar
Just keep going Brinny! Both caps off until the wing tank overflows, then replace that cap and keep filling, rad bleed bung out. When the bleed bung hole runs without bubbles, replace the bung and top up the central spout. When starting it, pointing the front uphill helps, but you MUST put the heater control to defrost before starting. This ensures coolant goes through the heater and helps fill the system generally. Once it has got semi-warm. stop it and remove the radtop bleed threaded bung (LHS of rad) and top up though the central filler spout until it runs out of the bleed hole. The replace bung top up central spout and restart. it is quite normal to have quite a few heat and cool cycles before all the air is out.
Old Jan 3, 2019 | 12:58 PM
brinny's Avatar
Ha ha ha, ok Greg. Be a bit longer before I turn the key.
Jon89
66
Apr 21, 2018 07:11 AM
FJG123
Jan 24, 2011 07:43 AM
x-typeandbeyond
Jul 30, 2009 10:03 PM
jag43v8man
Apr 17, 2008 04:50 PM
JimC64
Feb 25, 2008 02:47 PM
