Cooling fan diode pack
Old Oct 24, 2018 | 02:28 AM
MichelB's Avatar
Default Cooling fan diode pack
Hi,
Yesterday I took a multimeter to test the diodes of the cooling fan diode pack (1982 XJS V12 HE),
2 diodes had a value of about 524 both were 1N4006 diodes the other one was a different type and looked a bit of it was blown (it is somewhat dense)
How ever it tested to be good with a value of around 425.
So the question is is 425 enough? or is it bad?
And if I want to replace this one, will the 1N4006 do the trick?
Old Oct 24, 2018 | 02:55 PM
warrjon's Avatar
I assume those readings were with meter on diode mode, or was it on ohms. This makes a difference with the reading value.
A diode should read in one direction only, swap the meter leads and if it read in the other direction either the diode is bad or there is another component across it.
Old Oct 24, 2018 | 04:38 PM
MichelB's Avatar
Yes the meter was on diode mode, and it did read in one direction only but since the values were so different between the first 2 1N4006 and the last one I wandered if this is normal
Old Oct 24, 2018 | 10:10 PM
warrjon's Avatar
That's what I suspected. I'd call the diodes good.
What is the problem.
Old Sep 4, 2020 | 05:20 AM
DBU's Avatar
DBU
Default Diode Pack Location
Hi, sorry for a basic question but I’ve looked at the diagram for item 24 the diode pack for the fan. It looks like it would be in the middle of the engine bay under the windscreen, but I can’t find it? Is it under the bonnet or is it accessed from inside the car somehow?
Thanks in advance
Old Sep 4, 2020 | 06:46 AM
malc4d's Avatar
On my car its under the bonnet in the left side row of relays. This a '93
jgrasmehr
Apr 22, 2016 02:16 AM
leep123
Feb 8, 2016 01:57 PM
Doug
Dec 19, 2015 01:22 PM
George M.
Jun 14, 2014 10:20 PM
bsprowls
Jan 20, 2012 09:26 PM
