Cost for replacing 1988 xjs rear break
Old Nov 26, 2013 | 03:39 PM
jomia092306's Avatar
Default Cost for replacing 1988 xjs rear break
my mechanic is charging me around 1200 to replace my rear break. is that a good price. i live in san diego. any suggestions ?
Old Nov 26, 2013 | 08:12 PM
93greenconv's Avatar
I live in Chicago, but that sounds average. I was quoted $1100 about 2 years ago, but I decided to do it myself. Not an easy job, I believe yours are inboard brakes,like mine are, so it requires the shop to drop your complete rear end to get to the brakes, if they're installing new rotors, which for $1200, they better. I believe in mid-1993 they switched over to outboards ( much easier and cheaper to replace) Good luck
Old Nov 27, 2013 | 02:05 AM
Greg in France's Avatar
Do ensure the discs, pads and calipers are renewed and handbrake mechanism fully cleaned and lubricated with new bronze forks and pads used. Also that the rear brake flexible is renewed. The extra parts cost is relatively small and if done properly you will be good for 10 years.
Greg
Old Nov 27, 2013 | 08:06 AM
Doug's Avatar
That's sounds about right if he's replacing the pads, calipers, and rotors.
Replacing the pads alone doesn't take 30 minutes !
Old Nov 27, 2013 | 08:24 AM
Scoupe89's Avatar
I've replace inboard pads on the E type and it is a 30 min. job through the rear seat area. The S with inboard requires a skilled mechanic and can be done in about an hour. It is still a PITA without a car lift!
Old Nov 27, 2013 | 08:33 AM
Doug's Avatar
Skilled mechanic?
Pull the pins out, remove old pads, drop in new pads, reinstall pins!
But, yeah, if it's a DIY job you'll spend 30 minutes getting the car up and on jackstands.
Robert1968
Jun 24, 2017 11:16 AM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
SatanClaus
Aug 29, 2015 09:15 AM
dpappyp
Aug 27, 2015 06:31 AM
