Dead Battery
Old Mar 25, 2012 | 05:31 PM
olsthro's Avatar
Default Dead Battery
I have a 1995 xjs Convertible. LHD.
Occasionally the engine air compressor (Emission control) comes on after the engine is turned off and drains the battery. Is there a relay that controls this??
Old Mar 26, 2012 | 12:44 PM
Sarc's Avatar
Are you sure it's the air pump thats coming on and not the electric fan ? The airpump is mechanically driven off the crankshaft, so I think it's impossible for it to run without the engine running, and also it's not electrically powered.
The fan will sometimes "run on" after the engine has been shut off, but it is controlled by a thermostat and should go off after a few minutes, so it should never flatten the battery. First confirm whether it's the electric fan thats running, then we can help you troubleshoot whats wrong with it
Is this a 6.0 V12 or a 4.0 I6 ?
Put your car details in your signature, then we don't have to keep asking
Old Mar 27, 2012 | 08:08 AM
olsthro's Avatar
Yes it is the air compressor pump. It is a 4.0, I6 cylinder. The pump is electric. I have it unplugged at the moment and this causes the Check Engine light to illumminate. Something is turning it on occassionally when the engine is off.
Old Mar 27, 2012 | 02:21 PM
Sarc's Avatar
@olsthro
Wow, ok, I stand corrected. I had a look at the circuit diagram and the air pump is driven by a relay that is connected to 12V battery power (not ignition power) so in theory, if that relay is failing and closing when it shouldn't, your air pump could start running when the car is turned off.
This relay is on the left hand side component panel under the hood, at the back of the panel on a green base. I would start by inspecting and/or replacing this relay first. If it's not that, I would inspect the wiring loom from the ECU because the pump is activated by grounding the output, so if you have a short somewhere, this could also start the pump running, although it would seem strange that this short is happening when the car is completely still ? (Usually intermittent shorts happen when the car is moving and something jostles against something else)
Old Mar 28, 2012 | 05:51 AM
olsthro's Avatar
Thanks so much. I will try and locate this relay, replace it and see if that is the solution.
Old Apr 2, 2012 | 07:26 PM
olsthro's Avatar
Default Dead battery
I can;tseem to fnd the relay you referred to. I don't see any on the left side that have a green base. They mostly are all blue bases.
R
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
Rivguy
Nov 13, 2022 02:55 AM
ferraripete
Sep 12, 2016 09:02 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
