Dead radio
Old Jul 25, 2020 | 05:59 PM
Isitajagtho's Avatar
Default Dead radio
Thanks for looking, as the title says my radio is dead. I replaced an old pioneer cd radio, with a newer aux/bt. I got it working and went to clean everything up, and plug it back in. After doing so, I would hear the antenna relay in the trunk turn on, but the radio stayed off. I checked all fuses, and the inline fuses near the radio, and trunk. What did I do now...
1986 Jaguar xjs 5.7l
Old Jul 25, 2020 | 09:37 PM
VancouverXJ6's Avatar
Is there a fuse IN the radio itself? Like the oem jag model.
a volt meter should tell you where and if power is/isnt getting to it
Old Jul 25, 2020 | 09:41 PM
Yes, and i tested both radios afterwards, neither fuses blew. Checked my fuses under the dash with voltmeter and came across 2 with no voltage but did not blow, I have no panel with labels so I don’t know which is which. There is no juice going to the constant 12v neither.
Old Jul 26, 2020 | 07:14 PM
Got it working.
Old Jul 26, 2020 | 08:02 PM
garethashenden's Avatar
Originally Posted by Isitajagtho
Got it working.
How?
If you tell us it may help the next person who searches for this issue
Old Jul 28, 2020 | 12:24 AM
Originally Posted by garethashenden
How?
Bad ground to the main plug for the 12v hot and antenna. Took off my vent interior around the gas pedal and found a ground, took my ground from the plug and grounded it there. Turned on.
93greenconv
Aug 12, 2022 11:16 AM
SamtheSham
Sep 27, 2019 01:02 PM
93xjs6cyl
Apr 27, 2017 10:41 PM
steve p
Apr 2, 2008 08:39 PM
