Dead spot?
Old Nov 2, 2015 | 04:22 PM
RogB's Avatar
Default Dead spot?
Today the car would not start. Turning key produced no crank. All lights on dash were on. This has happened before but not since starter relay was replaced. Thought the problem was fixed.
On a hunch I let the car drift back a few feet, and it started right up. Coincidence or could that be a clue to the problem?
Thanks for any help. Glad car was in driveway instead of far from home.
Old Nov 2, 2015 | 05:13 PM
Doug's Avatar
XJS? What year and engine?
Old Nov 2, 2015 | 07:05 PM
baxtor's Avatar
How did you let it drift back a few feet. If it involved moving from park to neutral it may be a big clue. Micro switch on shifter not set correctly maybe.
Old Nov 2, 2015 | 07:37 PM
RogB's Avatar
Default Dead spot
Yes, moving from P to N. Car is 92 xjs
Old Nov 2, 2015 | 10:45 PM
baxtor's Avatar
Which engine /gearbox?
Old Nov 3, 2015 | 12:24 AM
Doug's Avatar
The safety switch at the gearshift is a likely suspect, as mentioned. Next time the problem occurs tries jiggling the gearshift. Any change?
If no change....
Locate the white/red wire, and the solid brown wire, at the starter relay. Touch or jump the two wires together. If the starter now operates you have a problem with the relay or a problem upstream of the relay. If the starter does not operate, the problem is downstream of the relay-- the starter itself or the starter solenoid.
Old Nov 5, 2015 | 09:33 AM
RogB's Avatar
Default Dead spot/Antenna
Thanks for the advice about the switch, I'm sure that's the problem, it wouldn't start in P but fired right up in N although in the am when cold it always starts ok in P.
Btw any ideas why sometimes the antenna fails to go up? Happens now and then, no particular pattern.
tommyd
Jun 4, 2016 01:44 PM
Dean9785
Mar 21, 2016 08:21 AM
Sentinelist
Oct 29, 2015 08:07 AM
Zues
Oct 28, 2015 10:45 PM
lioncub
Oct 27, 2015 04:13 PM
