Deep or Shallow transmission pan
Old Feb 15, 2025 | 10:48 PM
flyingphil's Avatar
Default Deep or Shallow transmission pan
I want to order a transmission filter and gasket. Rockauto is asking if I have a 'shallow'or 'Deep' transmission pan. I have a 95 4.0l XJS. Where would i find this information?
Old Feb 16, 2025 | 02:59 AM
Keesh's Avatar
You need this one, so for a shallow transmission pan. Partnr: LJM664 JLM 664
Old Feb 16, 2025 | 05:28 AM
ptjs1's Avatar
Keesh, is almost correct.
The correct part number for the XJS 4 litre filter is JLM664
DO NOT buy the part number that is quoted on the Jaguar Parts website. This system also drives the numbers that are used by independent suppliers who will be quoting the same incorrect part number. An error crept in about 8 years ago and the number is quoted as JLM2128 THIS IS WRONG and will not fit. I asked Jaguar to correct the error years ago, but it is still there. Your post has prompted me to contact them next week and request again.
Paul
Old Feb 16, 2025 | 06:10 AM
Keesh's Avatar
Paul
Typo. A bit strange actually, my X300 4.0 has the same gearbox but has a different filter than the XJS 4.0.
Old Feb 16, 2025 | 06:25 AM
ptjs1's Avatar
Keesh,
That's where the error crept into the Jaguar parts system, I think, about 8 years ago, when they updated a number of the systems, incl. the x300. And the x300 gearbox filter number (with the deeper sump) somehow got transposed over to the XJS area. Why the gearbox sump on the x300 is deeper, I don't know. Perhaps the XJS one has to be shallower for ground clearance?
Paul
Old Feb 16, 2025 | 06:45 AM
Keesh's Avatar
Keesh,
Paul
That's what I understood from my mechanic too. The ground clearance of an XJS is 15mm lower.
Old Feb 16, 2025 | 04:32 PM
flyingphil's Avatar
Thank you for all the responses! Duly noted and parts ordered.
Darrol2004
Jun 10, 2020 10:44 AM
05S-Stype
Jun 25, 2016 04:11 AM
STYPE1
Jun 26, 2014 10:12 AM
Casper
Nov 25, 2013 10:33 PM
