Differential oil change in 91 XJS,
Old Mar 15, 2018 | 05:14 PM
DaveL's Avatar
Default Differential oil change in 91 XJS,
Looking for information on changing the Diff oil, how much fluid will it take and how much anti slip additive should be used?
Old Mar 15, 2018 | 06:04 PM
Don B's Avatar
Hi DaveL,
I have moved your post from the forum for the XJ40 to the forum for the XJS. Here you will find knowledgeable owners of similar cars.
Cheers,
Don
Old Mar 16, 2018 | 02:09 AM
Greg in France's Avatar
About 2 litres. Use diff oil specially formulated for LSD diffs, not additives.
See this recent thread:https://www.jaguarforums.com/forum/x...al-oil-197694/
Old Mar 16, 2018 | 03:22 PM
brinny's Avatar
Hi, I have just changed mine and in the book it states 1.6 litres. I filled mine through the speedo hole which is a bit higher than the fill plug and as Greg says I got 2 litres in. It wouldn’t have taken a drop more though so use your own judgement when filling if you don’t want lots of mess. I also used lsd oil that was recommended by Greg .
Old Mar 16, 2018 | 03:24 PM
brinny's Avatar
Another excellent piece of advice given on here by one of the lads was not to remove the drain plug until your sure the fill plug will come out!!!
JimC64
Apr 16, 2015 08:20 PM
JimC64
Feb 13, 2014 07:35 PM
sjuraud
Aug 28, 2010 02:11 PM
JimC64
May 4, 2008 09:58 PM
FL XJR
May 3, 2008 09:55 PM
