Disable Alarm
Old Aug 17, 2023 | 11:09 AM
Segler56's Avatar
Resolution to 1995 Jaguar XJS alarm problem:
This was perplexing to say the least, because I could only work on the problem with the 7.5 fuse loaded that controlled the alarm, and the alarm was sounding. After disconnecting the wire at the sounder, I utilized the sequence described in this Jaguar Forum to reprogram a Jaguar remote. I only had to do it one time and the headlights stopped flashing. The remote was also once again functioning. I reconnected the sounder and the alarm problem was solved.
What made this hard was not being able to calmly work on the problem while the alarm was sounding, and having a lot of difficulty in quieting the alarm with the 7.5 amp fuse in place.
Thanks to my advisors as I worked through this. All the information I needed was in this forum.
Regards!
jean HJ
Jul 9, 2021 08:46 AM
Eldorado98
General Tech Help
Aug 5, 2020 02:13 PM
Simon99
Oct 10, 2019 08:14 AM
kevy1
Jul 7, 2017 05:18 PM
vai1953
Nov 15, 2010 05:49 PM
