Dizzy rebuild kit part number
Old Feb 7, 2017 | 09:12 PM
JigJag's Avatar
Default Dizzy rebuild kit part number
does anyone know what the part number for the dizzy rebuild kit is? I can not find this using google.
Old Feb 7, 2017 | 09:14 PM
Doug's Avatar
I never knew anyone offered such a kit
Old Feb 7, 2017 | 10:08 PM
JigJag's Avatar
I guess I just had to ask before I was able to find it. Just now I found the article. Guess it doesn't help me since it doesn't seem to contain the springs anyway. Maybe the Jag dealership has them.
DISTRIBUTOR SERVICE KIT: A distributor service kit, part number DZB105, is available; it is often called an "anti-flash shield kit" since the anti-flash shield is the most obvious part in the bag. The kit contains parts usable on all pre-Marelli distributors.
The mail order catalogs may not list what parts are supplied in this kit, so the list is provided here:
Clear plastic anti-flash shield (used on 1982-89 only)
Screws and washers for anti-flash shield (4 ea)
Ignition pickup mounting screws (2 ea - used on 1982-89 only)
Distributor cap gasket
U-pin for reluctor positioning (used on 1982-89 only)
Reluctor retaining clip and wavy spring washer
Replacement carbon contact for distributor cap, with spring
O-ring for distributor-to-engine joint
Nylon rotor retaining clip (see note under Distributor Disassembly above)
Old Feb 7, 2017 | 10:19 PM
Doug's Avatar
Jaguar XJ12 XJS Distributor Service Kit DZB105
Old Feb 8, 2017 | 10:33 AM
ronbros's Avatar
i wouldnt know, i just use all GM Delco parts, including weights and springs , easy to mod the advance curve, to a personal preference!
Old Feb 8, 2017 | 02:22 PM
JigJag's Avatar
any part numbers that you know? I'd be willing to do some research.
Old Feb 8, 2017 | 04:09 PM
ronbros's Avatar
i dont think any parts you mention would interchange with the GM parts.
have no idea part #s been 20 odd yrs!
Old Feb 12, 2017 | 07:59 PM
davidboger's Avatar
Thanks Doug..
Yeah I've got several of those DZB105 kits on hand:
David
