Does anyone have a self dimming mirror?
Old Apr 15, 2013 | 11:09 AM
Spikepaga's Avatar
Default Does anyone have a self dimming mirror?
Hello,
I want to install a self dimming rearview mirror on my XJS because it seems that as low as she is, I always have headlights right on my rearview mirror. Since I am going to have to wire it (wish they had a battery operated one available) I am going to get one with Homelink to program gate remotes and maybe with a back up camera built in.
Does anyone have one of these installed in their XJS?
Old Apr 15, 2013 | 02:21 PM
anjum's Avatar
You can power it from the overhead light. Try a second hand one from a car in the breakers or ebay. Back up camera would be useful!!!
Some have an additional wiring so it knows when you are in reverse but you can connect without that option.
Old Apr 16, 2013 | 06:03 AM
Steve M's Avatar
I had one of these and it worked a treat.
LCD Car Mirrors
Old Apr 16, 2013 | 12:19 PM
rgp's Avatar
rgp
there ok and will do what you want,i bought a new one from jaguars a few years ago, i ran the wires down the a post as it needs two feeds 1 from the lights and one from ign on side, you can just see it in the picture
good luck
Old Apr 17, 2013 | 01:32 AM
Spikepaga's Avatar
Thanks so much everyone for the links and pictures. It's exactly what I needed to make a decision. It looks fairly easy and not too intrusive. It looks great too.
I may or may not end up getting the one with the back up camera. On one hand I might as well since I am doing this, on the other I really see no "need" . Ill post pics when I am done
Thanks!!
Old Apr 17, 2013 | 09:11 AM
MustangSix's Avatar
I used one from a Buick or some such GM car in my Miata; not sure what it came from originally. Apparently, there is little difference between it and the expensive OEM versions from Jag and other car makers. I grabbed it and the connector going to it for about $25.
The mirror can be wired up to work constantly but there are other wires to allow it to work only when the headlights are on or to power down when reversing, for example. There is a light sensor in the mirror which turns it off in daylight so it really only dims when its dark anyway.
To use one like this, you'll need to glue a mounting tab to the windscreen.
DFW
Jul 27, 2020 02:44 PM
King Charles
Oct 16, 2015 01:25 AM
Jaguar Forums Editor
Jaguar Press release
Sep 30, 2015 03:08 PM
Sep 28, 2015 05:18 PM
