Does anyone know the rate of fuel flow..
Old Jun 13, 2015 | 08:17 PM
sirreginald's Avatar
Banned
Default Does anyone know the rate of fuel flow..
Does anyone know the rate of fuel flow that an internal jaguar electric fuel pump puts out on a late model face lift xjs? I'm not talking the actual pressure which I'm told can surge to upwards of a 120 p.s.i. (let me know if that's right or wrong, I'm thinking it's only, like, about 60 at the most anyway), but whether or not it flows around 30 g.p.h. or 45 or as much a 90 or 200, which I doubt on those last two higher numbers. More likely it's about 30. at least I hope, so I can use it properly with the new fuel pressure regulator with the proper size return line, approximately 5/16" 's or really around 8 mm. I'm trying to use a Mallory 4307m regulator with the Jags system to drop down the final pressure to around 5 to 7 for a carbureted chevy 305 with a roller cam, and slightly larger than an RV cam camshaft.
Old Jun 13, 2015 | 08:40 PM
Vee's Avatar
Vee
My manual says that pressure is kept constant within the range of 35-45 lb/in2.
Does that help?
Old Jun 13, 2015 | 08:43 PM
Vee's Avatar
Vee
It also talks about delivering fuel at 120 liters per minute at 3 bar.
That's probably not what you were looking for.
Old Jun 13, 2015 | 09:19 PM
Banned
Default hey thanks...
yeah that's exactly, that works out to about 30 gallons per hour, exactly what I need. thanks again
dsnyder586
Dec 29, 2024 07:39 PM
weisberg
Mar 25, 2021 05:47 PM
JWheeler
Nov 22, 2019 08:28 AM
RoyLittle0
Sep 17, 2015 01:05 PM
deanh
Sep 6, 2015 08:20 PM
