Door Panel and Plinth? Removal-'89 Conv
Old Jan 15, 2012 | 08:43 AM
mzitelman's Avatar
Default Door Panel and Plinth? Removal-'89 Conv
I need to remove the interior door panels. There is one fastener I can't get to. It seems to be behind the front of the armrest where it curves into the panel but there are no screws evident.
How do I access this?
Also, I need to remove the body piece (plinth?)that houses the back up lights. Screws are straight forward, but it doesn't seem the hole is large enough for the connector to slip thru. Don't want to cut wires.
Thoughts?
Thanks!
Old Jan 15, 2012 | 09:23 AM
Flint Ironstag's Avatar
Armrest: the chrome cap slides back over the leather of the armrest. Once you've wiggled it back, you'll find a screw.
Not sure about the backup lights.
Old Jan 15, 2012 | 10:06 AM
mzitelman's Avatar
Default It worked
Thanks!
Old Jan 18, 2012 | 07:24 AM
mzitelman's Avatar
Default Plinth removal
It turns out that when the grommet is removed from the trunk the hole is large enough to get out the wiring connector.
Off to the body shop now.
Jose
Dec 18, 2021 08:16 AM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
salP3082
Sep 25, 2015 05:07 PM
sadepol01
Sep 11, 2015 05:26 AM
