drive belt
Old May 15, 2014 | 02:28 PM
rgp's Avatar
rgp
Default drive belt
power steering drive belt has this no on the o/d 13 x1075 when fitting this belt its a right pita there is not enough adjustment to make it an easy fit
and the filler for the steering reservoir is obscured by the top hose, the one I have fitted is jaguar its just short
what no. would make the belt an inch longer?
Old May 19, 2014 | 08:14 AM
sidescrollin's Avatar
You have to tighten it all the way down. Not to sound smart but an inch longer would be a 14x1075
here is a chart in regards to numbers and specifications
Raw-edge V-belt
Old May 20, 2014 | 01:18 AM
Greg in France's Avatar
RGP
There are plenty of places that will make you up a V belt. RS for one. All you do is give them the measurements of the outside and inside width and the length required.
Greg
Old May 20, 2014 | 05:24 AM
The "13" is the belt "V" section, NOTHING to do with the length. It is the width of the TOP of the "V" in Millimeters. Some languages call it the "profile", dunno why. Same as an 11A belt is narrower, being 11 mm across the top of the "V".
The "1075" is the length in Millimeters.
I have AWAYS used a 13A1090 in that application. Steer cap is still a MONGREL, but not as bad as that short sucker would make it.
Old May 20, 2014 | 07:49 AM
yeah somehow i glanced at that chart quickly and managed to get lost on a line that was only about 2 inches long lol.
other than getting a different belt, removing the tensioner and cleaning the threads helps a lot. most of the reason mine took so long to move back and forth was that it required wrenches either way, because it was so dirty
Old May 20, 2014 | 08:07 AM
Agreed, and that adjuster on the steer pump is real easy to get to, NOT.
Old May 20, 2014 | 08:17 AM
yeah i recently purchased some ratcheting wrenches to make changing belts easier. I can't use any of them, the throw is too long and the wrenches themselves are too long. Flat by flat by stupid flat....
Its always the damn alternator belt too.
the PS does seem to be the worst to get on an off though, it has to be as tight as possible.
Why jaguar provided 4 lightyears of extra bolt so no one can use a socket I haven't got the slightest clue
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
Raul Lara
Sep 14, 2015 07:31 PM
JimMLiny
Sep 9, 2015 08:13 PM
Xkr x100
Sep 6, 2015 08:50 AM
