Driver’s side rear window on 1994 XJS 2 + 2 convertible
Old Apr 26, 2026 | 01:24 PM
Rchuda's Avatar
Default Driver’s side rear window on 1994 XJS 2 + 2 convertible
Driver’s side rear window does not go down when convertible top goes down. Passenger side is fine. Where do I start?
Old Apr 26, 2026 | 05:40 PM
ptjs1's Avatar
Start by checking that current is going to and from the relay for that window.
Paul
Old Apr 26, 2026 | 08:20 PM
Vee's Avatar
Vee
Search the forum. This is a common problem. I have a good post on it with pics.
Short answer is getting a long screwdriver will allow you to tap on the motor housing. That will get it to work for at least a short while.
Long answer is removing the motor, and taking it apart to see what the problem is. It, most likely, can be fixed.
Cregan
Nov 3, 2024 10:19 PM
Zarathushtra
Nov 5, 2023 12:59 PM
Mbower1967
Oct 22, 2023 01:15 PM
JayJagJay
May 20, 2021 06:32 AM
NCJagman
Oct 12, 2017 08:23 AM
