Drivers Door Handle
Old Oct 11, 2018 | 03:54 PM
dborthwick's Avatar
Default Drivers Door Handle
So I went to open my door as usual, and the drivers side handle lifts, but there is no tension behind it, and the door does not open. The door still locks, and can be opened from the inside, however the outside handle is useless. Is this an easy fix please?
Old Oct 11, 2018 | 07:59 PM
kjopen's Avatar
Hi,
I have just done this exact job myself two weeks ago. I'd say its medium rated job, mainly because it is very 'fiddly' to get the actuating rods clipped back in place. I attach a few pictures I took, not to easy to visualize/relate to the handle however, gives you an idea how tight room is!
I also attach a picture of the broken handle so you know what you need to replace....
Last edited by kjopen; Oct 11, 2018 at 08:11 PM. Reason: photos aren't appearing??
Old Oct 11, 2018 | 08:15 PM
kjopen's Avatar
photos wont upload..., PM me your email address and I will send them you
just incase a moderator is looking in, the photos are around 3.5Mb and none of them will upload, individually or together.
Old Oct 13, 2018 | 10:39 AM
sidescrollin's Avatar
Not a hard job, remove the door panel to get to the handle. It could be that the linkage is popped out, the clip the linkage goes into is broken, or the door handle itself is broken.
Unless you popped the door after locking yourself out, its unlikely the linkage just popped out and nothing is wrong. My guess is the clip broke or your door handle is broken. When this happen on my XJS it was the door handle itself, the arm is cheap pot metal that can only be stressed so much. Either way, pretty easy fix. Remove/replace door handle or replace the clip.
Jon89
Apr 5, 2019 01:23 PM
itspec60
Apr 14, 2016 07:31 AM
wrd0225
Mar 6, 2014 10:35 AM
G1983
Jan 23, 2011 10:32 PM
kennith13
Dec 12, 2010 09:27 PM
