Drivers window binding
Old Jan 9, 2013 | 05:44 PM
Knomad's Avatar
Default Drivers window binding
The drivers side window on my 1996 XJS 2+2 makes a noise of glass scraping against metal. It is most noticable when rolling the window up with the door closed.
If I raise the window up and down with the door open, the scraping sound pretty much goes away. There does not seem to be any marks on the window.
The car is currently is storge for the winter, but this will propably be my first spring project.
I'd appreciate any thoughts as to what I will be getting into.
Old Jan 10, 2013 | 11:08 AM
Greg in France's Avatar
You have frameless windows, so the sound is most likely to be from the channels in the door. Remove the door trim panel and have a look at the channels, which usually have a metal outer u with a rubber U channel fited into the metal one, with a furry velvet inside to the rubber U. Probably the glass has worn though the rubber/fur somewhere. New linings can be bought and basically pressed into the metal outer channel.
Maybe a squirt of silicone in the channels will do the trick on its own. Worth a try.
Greg
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
sadepol01
Sep 11, 2015 05:26 AM
