Electric radiator fan
Old Aug 5, 2015 | 09:47 PM
RagJag's Avatar
Default Electric radiator fan
My 1996 4.0 overheats a bit in traffic on hot days, hot enough to turn the electric fan on. It was running and I cut the engine off and with the bonnet raised was surprised to find that no air was coming through the radiator. All the air was blasting upward from between the fan shroud and the ac condenser.
I pulled the flexible rubber sheets away from the back of the radiator and still got no airflow. It seems as if the ac condenser or the radiator is clogged up with dirt although I can't see any.
Have any of you experienced this?
RagJag
Old Aug 5, 2015 | 11:38 PM
Doug's Avatar
Radiators being externally clogged with debris is common....and doubly so on Jags, it seems. The fins are finer and hold the debris.
The rad on my XJS was fully 30% clogged. I had to remove it for a thorough cleaning
Wahooesprit
Dec 23, 2019 02:01 PM
Blaine Trarop
Sep 23, 2015 03:08 PM
Tipptone
Sep 16, 2015 07:39 AM
frank regalado
Sep 16, 2015 06:15 AM
1100me
Sep 7, 2015 06:26 AM
