EM brake pad replace
Old May 23, 2016 | 10:34 AM
catterwaller's Avatar
Default EM brake pad replace
SNJ Barratt offers Kevlar emergency brake pads. Do these have a better bond with the backing plate? The ones I'm replacing had one where the bond gave up. I read that this is a common problem.
Old May 23, 2016 | 10:51 AM
Greg in France's Avatar
Excellent point, ask them. Having had real problems with mine at the car road test, I redid my (in UK speak) handbrake to make it far, far better, and I used footbrake pads with a modern system of backing, cut down to size, plus various other mods. In case you are interested, I attach the paper I wrote explaining it all.
Greg
File Type: pdf
Old May 24, 2016 | 11:52 AM
I contacted SNG Barratt. They couldn't tell me anything definite about the Kevlar pads having better bonding. There answer was just that they were excellent pads made by reputable manufacturer and carried (I believe they said) a 1 year warranty. It's a bit disappointing since about the only thing preventing lifetime service is the bonding.
Old May 26, 2016 | 12:20 PM
davemack's Avatar
Greg
Greg, not to "hijack" another members post, but I want to thank you for sharing your paper on hand brake improvement. I just bought a 96 XJS-C and thought the hand brake was inoperable - I could pull it and it felt like the cable was disconnected, since the lever moved freely up and down. Another member said he had the same issue, but realized a transport driver had really yanked the lever up to engage the brake. That gent tapped his "ratchet bolt?" and the brake released. I went to my car, gave a good pull on the lever while pressing in the release button and sure enough, the lever released.
Of course, the brake is still inop, but that is probably because the car has been driven with the brake engaged. I now have something to inspect - whether the pad has come free from it's backing. If all I need to do is replace the pads, I'm a happy man.
Thanks again for a useful post!
Old May 26, 2016 | 01:58 PM
Doug's Avatar
It IS very useful advice from Greg.
However, you have a 1996 XJS, correct?
If so, you have a different parking brake system entirely. You have outboard calipers and parking brakes. Greg's article refers to 'inboard brake' cars.
Old May 26, 2016 | 02:05 PM
Quite true Doug, but I GREATLY appreciate the thoughtful "thank you" from both you and Davemack. Thanks to you both
Greg
Old May 26, 2016 | 04:05 PM
davemack's Avatar
Ahh yes, I do have the 1996. I thought the park brake system would be the same. Well, I need to focus on the front end first, and can look at the park brake checked when I have the car in the shop. There is an issue - wheel bearing, hub assembly, axel, ?? on driver side rear anyway, so once it's apart they should be able to tell me what the issue is.
Regardless, it was nice of Greg to put that tutorial out there. I'm sure others will find it both useful AND applicable.
coxzilla97
Dec 11, 2018 02:43 PM
Wrightway
General Tech Help
Jul 25, 2016 02:53 PM
JeffXKR
May 23, 2016 10:13 PM
Pilotman11
May 22, 2016 11:00 AM
Addicted2boost
May 21, 2016 08:30 PM
