eng bearing
Old Mar 11, 2024 | 01:25 PM
Richard Portale's Avatar
Default eng bearing
1995 xjs 6cy I have been told by my shop that I have a bad engine bearing , my question is what can be done to fix or replace. and are the bearings accessible by removing the oil pan. Help please
Old Mar 11, 2024 | 11:51 PM
MMMMM, that would be rare indeed, unless its run without oil, NAH.
Have them check the huge bolt that holds the crank pulley to the crank, they come loose, rarely, but knock badly when they do.They will need to jam the flywheel to tighten it properly.
If it deemed loose, I recommend removing it, and ensure the Woodruff keys in there are still good to use, or the symptoms WILL return.
YES the bearings are accessable with the sump off, but that is a HUGE labour intense job, and I have never had a bearing failure on any Jag engine in all my time.
Old Mar 12, 2024 | 12:49 AM
Jagboi64's Avatar
It depends if it's a rod bearing or a crankshaft bearing, rod bearings are easier ( but not easy) to replace with the engine in the car. For a crankshaft bearing, it's usually an engine out job to do it right.
I'd be very surprised of it was a bearing though, as these engine are virtually indestructible on the inside, assuming they have not been starved of oil. Because of the low demand, the bearings are no longer available from Jaguar, I don't know if there are any aftermarket options.
I'd want to be very sure of the diagnosis before going too much further, just because it's such an unusual failure. The engines are the same as the 1995-1997 XJ6 sedans, so it might be cheaper to find a good used engine and drop that in, then to try and find bearings.
Old Mar 12, 2024 | 06:43 PM
icsamerica's Avatar
I have an engne... have 2 perfect AJ16's left over from two XJR swaps.
If in fact you do need a engine I'm willing to sell an engne or buy a car that needs an engine. PM me contact info to discuss.
Old Mar 14, 2024 | 09:09 AM
Default XJS engine
Thanks for the response,what engines do you have for sale? can you give a description, include price please,
Old Mar 14, 2024 | 09:11 AM
please let me know what you have for sale, include condition and price thanks
Old Mar 14, 2024 | 10:17 AM
ptjs1's Avatar
Richard Portale,
I'd also question the likelihood of a failed bearing. I would ask the mechanic what makes him think that is the case, as I've never heard of a bearing going on the crank of an AJ16 engine. AIso, is he saying he thinks it's a big-end or small-end bearing, or a Main bearing? I certainly wouldn't be thinking about a replacement engine yet.
Have you noticed a noise yourself? If so, where did it appear to be coming from? Is it there immediately at startup? Is it better or worse when it is idling or revving, hot or cold engine?
Good luck
Paul
Old Mar 14, 2024 | 11:11 AM
icsamerica's Avatar
I have 2 AJ16's. One wth all the ancilaries like intake, injectors, coils, manifolds etc for $2000 and one that is just the block and head for 500$
POD XF
Nov 13, 2023 05:28 AM
Pistnbroke
Oct 28, 2021 01:15 AM
liquidreality
Sep 9, 2014 08:08 PM
David's XKR
Aug 15, 2012 08:00 AM
lovemycar1
Aug 4, 2011 07:28 PM
