Engine bay pics.
Old Mar 17, 2012 | 08:02 PM
M90power's Avatar
Default Engine bay pics.
lets see them. My jag appears to be suffering from a severe case of amateur mechanic/electrician. ive noticed severel things out of place and missing, so instead of asking you what each thing is, how about you all post some good pics of your engine bays so i can get a good idea where everything goes.
TIA.
Old Mar 17, 2012 | 08:17 PM
JameyXJ6's Avatar
Until I get mine cleaned up I doubt you want to see it, it looks like something out of a horror movie!
Old Mar 17, 2012 | 08:37 PM
M90power's Avatar
actually, im especially interested in yours the way it is. i want to see as much of the wiring harness as possible, because ive found wires missing etc.
Old Mar 18, 2012 | 04:45 AM
JameyXJ6's Avatar
It's supposed to be a beautiful day today, so I'll try to remember to grab my camera and take a few pics. The wires on mine will look different for a few reasons. I've replaced most of it, and what wasn't needed has been removed. I've deleted the A/C, cruise, airpump, secondary coil, relocated the amp and added an electric fan. I've also replaced the fuel injection harness.
I won't be able to post them until Monday or Tuesday. I currently hold the world record for the slowest internet connection at my house, so I can't upload until I get to my office.
Old Mar 18, 2012 | 08:45 AM
M90power's Avatar
well, maybe ill be better off posting questions about where things go. lol
Old Mar 18, 2012 | 08:49 AM
Doug's Avatar
Here' s a couple of mine
Attached Thumbnails Engine bay pics.-xjs-engine003.jpg   Engine bay pics.-xjs001.jpg
Old Mar 18, 2012 | 10:29 AM
ronbros's Avatar
Default 78 XJS engine pix
hope this helps, its not quite original!
Attached Thumbnails Engine bay pics.-mazda-jag-rodst-031.jpg   Engine bay pics.-mazda-jag-rodst-025.jpg   Engine bay pics.-mazda-jag-rodst-030.jpg
Old Mar 18, 2012 | 11:38 AM
M90power's Avatar
these are all really helpful. thanks guys. keep them coming.
Old Mar 18, 2012 | 03:39 PM
calvindoesntknow's Avatar
in the middling of doing some wire rerouting but you can see my fi wiring harness and how it goes on the old air rail bolts because i have that removed.
Attached Thumbnails Engine bay pics.-resampled_2012-03-18_11-20-54_277%5B1%5D.jpg
Old Mar 18, 2012 | 04:36 PM
M90power's Avatar
Very nice. that one is particularly good. quick question, where do the air rails get air from? the heads? i cant see any other place. ive seen some people remove them all together. how do you block the holes in the heads if thats the case?
Old Mar 18, 2012 | 08:04 PM
JameyXJ6's Avatar
By the time I got around to it, it was too dark, but I got a quick pic of the outside!
Old Mar 18, 2012 | 08:19 PM
Ronbros / doug.....nice engine bay guys, looking sharp
Old Mar 18, 2012 | 08:21 PM
ronbros's Avatar
mine was a European 1978, it came from factory without air pump or rails!
actually from England, RHD!
Old Mar 18, 2012 | 09:19 PM
Mish_Mish's Avatar
Here is mine, when I was finishing my FI harness.
BTW, when you do yours, I suggest you run new wires in hear tubing, along the fuel rails. This way there will be no more excessive heat exposure, like it is inside the Vee. Here is my video and I approve this message!
1982 Jaguar XJ-S V12 perfect engine! - YouTube
Old Mar 18, 2012 | 09:20 PM
Mish_Mish's Avatar
This is like perfect version of my underhood, I hate you!
Old Mar 18, 2012 | 09:43 PM
Doug's Avatar
Oh, absolutely. Getting the wires up out of the vee is about 90% of the upgrade. Exotic wires, heat-proof sheathing, etc is just icing on the cake :-)
Old Mar 18, 2012 | 09:49 PM
M90power's Avatar
now all you need is some Rouge type hood louvers.
Old Mar 18, 2012 | 09:50 PM
Doug's Avatar
Thanks.
Lots of work but none of it very difficult.
If you resign yourself to 2-3 weekends to, essentially, remove everything on top of the engine for repair-replacement-cleaning-painting, it really isn't all that hard. Sorta fun, actually. Just take lots of pics and make good notes :-)
As I mentioned elsewhere, do it all at once and be done with it.
Old Mar 19, 2012 | 02:54 PM
Copronymous's Avatar
Here's mine...right now
Old Mar 19, 2012 | 09:43 PM
M90power's Avatar
well heres mine. as you can see someone has tampered with it quite a bit. there are capped off vacuum lines everywhere, the throttle linkages appear to be missing bushing and theres some slop in them, the AC and smog pump have been removed, along with the cruise control bellows. even little things like the TPS has been removed and laid aside. i bolted it back on the other day but its only got two wires plugged into it, and a post for a third wire that is no longer connected.
all that white antifreeze residue is from my epic journey home (which ill save for another thread.)
