Engine Identification
Old Feb 23, 2019 | 02:24 PM
Whatcher3's Avatar
Default Engine Identification
Greetings all,
i wouldn’t be asking this if I hadn’t looked at the engine, owner’s manual, and an XJS service manual. Where do I look to identify which engine is in my 1990 XJS V12 Convertible?
thanks for any replies.
Old Feb 23, 2019 | 02:31 PM
Mac Allan's Avatar
There was only one engine available in the US in 1990 models - 5.3 liter V-12 HE, does that help?
Old Feb 23, 2019 | 02:34 PM
Doug's Avatar
Well, since it's a 1990 V12, and not an XJR-S, we know it's a 5.3 liter.
Since it's a 1990 we know it's Marelli ignition
Since it has Marelli ignition engine we know it's 11.5 compression
Assuming it was originally sold in the USA it'll have cat converters
Does that help?
Old Feb 24, 2019 | 02:13 AM
Greg in France's Avatar
FYI, the actual engine number is invisible, engine in car. It is at the rear of the block, just forward of the transmission/engine join. See post 2 on this thread for more info:
https://www.jaguarforums.com/forum/x...decode-133597/
The actual engine number when the change in V12 XJS ignition system from Lucas to Marelli occurred is believed to be during the 1989 model year at (or around) VIN 156989. But the "model year" has all sorts of meanings, so the VIN number is the best guide. If your engine has a distributor that looks like this with two king leads in the cap, it is a Marelli ignition car:
If it looks like this it is a Lucas ignition car (the white tube on top is a ventilation outlet)
Old Feb 25, 2019 | 06:13 AM
Whatcher3's Avatar
Thanks to all who replied. I guess I expected a big stamp or placard in a visible, prominent place on the engine. Didn’t happen.
Old Feb 26, 2019 | 02:14 AM
EcbJag's Avatar
It is *possible* to see the engine number with the engine in the car. As stated above it is located in the "V" on the top of the engine right ahead of the transmission bell housing. But it will likely be completely covered in oil from the hard oil lines that run above it and always leak. I sprayed some engine degreaser down there and took a long flathead screwdriver and scraped the oil and dirt away, and with a bright flashlight was able to read off the engine number; I'm sure you could do the same. I then printed out a label with the engine number and put it on the side of the engine bay so it will always be there if needed.
DZtt
Aug 13, 2018 03:51 PM
frederikv12beauty
Feb 11, 2011 04:49 AM
catdreams
General Tech Help
Sep 30, 2009 07:33 PM
