Engine sump plug size - 6 cyl
Old Aug 7, 2020 | 09:04 AM
leep123's Avatar
Default Engine sump plug size - 6 cyl
Hi all,
Went to change the engine oil on my 1990 3.6, 6 cylinder XJS but realised I don't have a socket big enough so will have to purchase. Looks like about 30mm or is it imperial? Anyone know the size?
My first engine oil change - anything to watch for?
Thanks,
LeeP
Old Aug 7, 2020 | 11:13 AM
Timeisrelative's Avatar
My 93 4.0 is a 30mm, or at least that fits it lol. Mine was tight as crap the first time I changed it, and only being able to use a jack and stands, there wasn't a lot of room under there. The other annoying thing was the filter placement. It dumped oil on pretty much everything below it when I did mine
Old Aug 7, 2020 | 11:35 AM
Vee's Avatar
Vee
My 1996 is a 30mm.
The last time I changed my oil and filter, some rains came and delayed the process. I was able to drain the engine for maybe an hour, perhaps even longer. When I finally came back to pull the dreaded oil filter, I found it relatively empty! I did not unload any oil anywhere! (I did have a rag to catch the minimal amount of oil it released)
I am going to try that again next time I change the oil, perhaps it will be a much less messy event?
Old Aug 9, 2020 | 03:47 AM
orangeblossom's Avatar
How Not to change the Oil on an XJS
dtony
Sep 14, 2014 10:48 PM
2007 Rick
Mar 22, 2014 11:28 AM
Xjs 1980
Nov 17, 2013 04:04 PM
1988xj6navy
XJ40 ( XJ81 )
Jun 20, 2009 09:02 PM
fall4it
XJ40 ( XJ81 )
Jun 8, 2008 09:58 AM
