Error code FF3
Old Jul 5, 2018 | 02:33 PM
Jagman87's Avatar
Default Error code FF3
This has appeared on the computer in a 1987 XJ-S 3.6 (manual) The car starts and runs normally but the starting is not instantaneous.
Could this be because the battery is fragile and does not readily hold a full chrge ot is it likely to be fuel pump/filter or the fuel pressure regulator. Thje error code can be prefixed by a flashing "Fuel Fail", but not every time.
Any advice would be appreciated.
Old Jul 5, 2018 | 03:09 PM
motorcarman's Avatar
If the Fueling Failure codes are the same as XJ40 then FF3 is Coolant Temp Sensor.
bob
Old Jul 6, 2018 | 05:35 PM
Jagman87's Avatar
Thanks for this Bob I replaced the coolant temp. sensor a couple of years ago at the same time as renewing the thermostat. The parts came from David Manners but OEM or original Jaguaar I can't remember. The car has run very little until recently when it is standing in for a sick XKR100. Today the error code flashed very briefly as FF8 with the usual fuel fail message. any ideas? The fuel comsumption has fluctuated between 31mpg on a run at motorway speeds to 23mpg on shorter trips.Seems normal!.
Filos Hippos
Feb 18, 2010 06:21 AM
2000blackxkr
Feb 18, 2009 02:25 PM
ahuber
Dec 25, 2008 03:11 PM
brgjag
Aug 13, 2008 01:34 PM
mvenco
Oct 19, 2007 11:50 AM
