Eurospare fuel sender wiring
Old Jan 17, 2024 | 11:20 AM
JJS- Florida's Avatar
Default Eurospare fuel sender wiring
Hi Gentlemen! Todays project is to replace the fuel sending unit. So far, so good, got the fuel drained down and removed old sender. Replaced gasket with new. The dilemma is the wiring, which is in a vertical column of three connectors on the Eurospare #W0133-1617470. I can figure out the ground wire, which is the top left (no insulator) on the original sender. I sure do not want to short anything out or blow anything up!!
Anyone with experience with the Eurospare unit?
Original unit.
Eurospare W0133-1617470
Thanks a million in advance!
John
Old Jan 17, 2024 | 01:46 PM
Default Wiring figured out
OK, crisis averted! I had to change the spade connectors on the car, as they were a bit too small. The car now actually reads darn near full (WAY over 3/4 mark) when I just gassed it up!
Top is on RT side, black wire (ground). Green/Yellow to middle, Brown/White to bottom.
Old Jan 18, 2024 | 09:28 AM
Greg in France's Avatar
John
Are you 100% sure that is the correct part? It looks like ones I have seen used in convertibles.
Old Jan 18, 2024 | 09:51 AM
Thanks, Greg! I am a day behind in posting. Further research revealed that this unit is indeed for a convertible, DAC-10183. It is on it's way out of the car, the proper unit is on the way. I saw the float arm was different, but passed that off as an aftermarket thing. Will have correct unit next week!
John
Bosco15
Jun 11, 2025 10:56 AM
Voucher Boy
Apr 3, 2022 05:22 PM
OldCoastie
Sep 13, 2020 08:14 AM
Nanonevol
Mar 30, 2018 08:33 AM
Boeingtravel95
Apr 28, 2016 05:36 PM
