Evaporator replacemtn
Old May 11, 2026 | 03:40 PM
Ginoxjs's Avatar
Default Evaporator replacemtn
Hi all first post here.
i would like to ask how many times i have to remortgage my house to get the evaporator done on the cat?
doesn any of you done it recently?
and do you know anybody that would do it around Surrey Berkshire Hampshire?
thank you in advance
Old May 11, 2026 | 04:23 PM
davchr's Avatar
Here is an AI answer which seems reasonable.
For a 1995 Jaguar XJS, replacing the A/C evaporator is a notoriously labor-intensive job because the unit is buried deep within the dashboard. You can expect to pay between $3,100 and $4,500 for a professional replacement at a specialized shop.
Cost Breakdown
The high price tag is almost entirely driven by the "dash-out" nature of the repair.
Category Estimated Cost Details Labor $1,600 – $2,400 Requires 10–20+ hours of work. Parts $200 – $2,100 Varies wildly between aftermarket and OEM. Recharge $250 – $380 Evacuating and refilling the refrigerant. Total $3,100 – $4,500 Average estimates for the 1995 model.
Why do you think the evaporator needs to be replaced?
Old May 11, 2026 | 04:39 PM
Ginoxjs's Avatar
Cost Breakdown
thank you for your help.
Old May 11, 2026 | 04:41 PM
Ginoxjs's Avatar
I know as it was diagnosed leaking but there is not many shops that wants to do it I have asked to couple for a quote but they tend to be very against it. I have now asked jaguar specialist in the area we will see the evaporator is not to expensive but I need to understand the labour hours some people say 8 some people say 12
Old May 12, 2026 | 06:30 AM
Greg in France's Avatar
If nobody else wants to help, try Classic Engineering in Waltham Cross. This is a big job labour-wise. Mine cost nealry 2000 quid twenty five years ago. The dash has to come out and so does the aircon unit, then all put back and regassed. Trouble is the XJS is undriveable without aircon in anything other than cold weather!
Old May 12, 2026 | 01:27 PM
Ginoxjs's Avatar
I found somebody and he is been quite honest too so I will get more work done to remove any leak
Old May 12, 2026 | 04:03 PM
ptjs1's Avatar
Ginoxjs,
Try getting a quote from Ray at Surrey Jags, Tom at Tom Lenthall Ltd in Finchampstead, or go further north and talk to David Marks at David Marks Garages.
Good luck
Paul
Old May 12, 2026 | 04:49 PM
Ginoxjs's Avatar
Originally Posted by ptjs1
Ginoxjs,
Good luck
Paul
I spoke to Tom lenthall thank you for the recommendation
Old May 14, 2026 | 09:30 PM
Elm's Avatar
Elm
I’ve just had the dash out of my ’89 XJS to investigate vacuum and electrics. Quite straight forward. Bigger job to remove the HVAC unit as water and A/c connections at firewall need detachment and trans tunnel panels removal required but all doable. Just takes time.
RF-NOLA
US Southern Midwest
Aug 9, 2022 02:05 PM
mapatton
May 14, 2014 11:31 AM
Stu 1986
Jun 7, 2011 07:52 AM
wade692@yahoo.com
Sep 9, 2008 11:27 AM
