Exhaust Manifold Bolt Broke!!
Old Jan 14, 2012 | 07:40 PM
hoodun's Avatar
Default Exhaust Manifold Bolt Broke!!
The exhaust manifold bolt on my 1994 xjs 4.0 snapped on me, on its own. I was able to drill the hole out and I tried to tap it. I got some thread going. I didnt want to go to far in in fears of hitting something so I only went in as far as the old bolt... Put a new bolt in and it worked for a week. Now its out again (the exhaust leak is loud when it is cold, like it was indicating a cracked bolt).
I need to drill farther in and try to tap out more thread or go with a larger bolt.
Does anyone know if I can tap in farther. I dont want to hit anything!
Recommendations appreciated. Is this a common thing? I first heard the leak a month ago and when popping the manifold I realized the broke bolt.
Old Jan 15, 2012 | 09:30 AM
anjum's Avatar
Try a helicoil of the correct size, Assuming you are talking about the head and that you didn't oversize the hole when you drilled the bolt out.
Old Jan 15, 2012 | 10:48 AM
hoodun's Avatar
the hole is not oversized. The original sized bolt will grab. Its just not grabbing very good. if i could go in a 1/4" or so more and tap it, I would be confident in it holding. I just dont want ot hit a valve or something. Its the 5th bolt from left to right (first bolt on the right exhaust manifold).
my back up plan is a helicoil as you mention.
I managed to torque it at 17 foot pounds, so I will see if it holds. though, it seems to be spinning in place at 17 and not getting any tighter...
Old Jan 17, 2012 | 01:39 AM
anjum's Avatar
If it's spinning then the thread is kaput. I would definitely go for a helicoil as a first option.
Old Feb 5, 2012 | 04:15 AM
hoodun's Avatar
I managed to get it to hold by tapping it a little farther in. Its been a couple weeks and all is ok.
When I removed the exhaust manifold there were three gaskets on both the front and rear manifolds. I am eventually going to replace the oil selas and head gasket, etc. The kit only comes with one gasket. Is there a reason why my car now has 3? Would going to 1 gasket cause leaks?
Old Feb 5, 2012 | 11:19 AM
mrtalkradio's Avatar
I hope this helps. I changed my exhaust manifold gaskets on my XJ6 about 3 weeks ago. When I took the rear gasket it out it looked like 3 were in there, but actually it was one that had come apart.
Old Feb 7, 2012 | 07:14 PM
hoodun's Avatar
makes sense. It seems that when they make the gasket they press three thin slices of metal together. I didnt notice any glue so it must just be pressed.
RaceDiagnostics
Jul 7, 2022 06:41 AM
TreVoRTasmin
Sep 16, 2015 08:14 PM
joesoap
Sep 10, 2015 01:09 AM
TC Johnson
Sep 2, 2015 09:30 AM
