Expansion Tank - Aluminium
Old Nov 8, 2018 | 12:31 AM
Crackerbuzz's Avatar
Default Expansion Tank - Aluminium
Got a pin hole in my tank...
Decided to build one from 3mm alloy.
Nice job!
Old Nov 8, 2018 | 01:02 AM
Greg in France's Avatar
Lovely job. What did you use to weld the aluminium please?
Old Nov 8, 2018 | 01:08 AM
warrjon's Avatar
Looks like TIG.
Very nice job, you could sell those
Old Nov 8, 2018 | 01:16 AM
AC/DC TIG.
I own an engineering business and my business partner is an aluminium specialist.
The radiator neck is pressed alloy.
We would be happy to build these for people if they are in the need.
Old Nov 8, 2018 | 01:47 AM
Daim's Avatar
Looking good! I'd recommend giving the inside a protective coat... Outside maybe as well...
Old Nov 8, 2018 | 01:55 PM
Jagsandmgs's Avatar
Very nice. The “Uro” brand steel repro tank sells for $130-$150 so a nice premium aluminum version would do well at a higher price.
Old Nov 9, 2018 | 01:25 PM
Doug's Avatar
Nice job, looks great!
Old Nov 9, 2018 | 01:28 PM
Doug's Avatar
For the benefit of anyone on a tight budget I'll just add that your local radiator repair shop can often repair your existing tank if it isn't too far gone.
Old Nov 9, 2018 | 08:29 PM
Ezrider's Avatar
that came out very nice. well done.
Old Nov 9, 2018 | 09:32 PM
VancouverXJ6's Avatar
Where does your top hose go off the neck? And can you easily change the shape but keep oem mounts, coolant sensor holes etc? I'd rather buy from the community then a random supplier of honda/gm junk
I was going to buy a aftermarket one it was more tall then rectangular, but same compact size, has a plastic? tube to visually see coolant level, and various fittings for adding crap like gauge probes. It was rather expensive
Old Nov 14, 2018 | 05:58 AM
Hi Vancouver... Top hose goes off under the engine. Guard tank failed so I don't use it now.
Jahmiata
Aug 9, 2018 09:33 AM
avern1
Apr 13, 2016 02:30 PM
X Ray
Apr 5, 2010 12:26 PM
sbxt
Feb 8, 2008 11:50 AM
androulakis
Sep 2, 2007 05:46 PM
