Extra Parts?
Old Sep 12, 2025 | 08:53 AM
Patrick 1989 XJS's Avatar
Default Extra Parts?
I am putting my car back together, and I have a few parts that I forgot where they go. Please look at the pictures and let me know where I need to reinstall them.
  1. Round Spacer 1a: 16mm OD, 9mm ID, 19.2mm 2 each
  2. Round Spacer 1b: 19mm OD, 10mm ID, 15.2mm tall 1 each
  3. Round Spacer 1c: 19mm OD, 10mm ID, 7.8mm tall 1 each
  4. Round Spacer 1d: 15.8mm OD, 8.7mm ID, 7.6mm tall 1 each
  5. Copper Round 1e: Spacer 1e: 19mm OD @ top, 25.3mm OD @ bottom, 15.6mm ID, 19.15mm tall 2 each
  6. 2-way Blocks: 28.6mm long, 19mm tall,15.8mm wide, 2 holes 9.5mm ID 3 each
  7. What is the size of the round spacer on the dampening pulley?
  8. Forked Shims: X-18 (8), JD-32WD (2) rear & front end locations?
File Type: pdf
Old Sep 13, 2025 | 01:23 AM
Greg in France's Avatar
The three blocks are part of the belt tensioning assembly.
Old Sep 13, 2025 | 03:02 AM
Those fork shims are from the Upper Wishbone Inner Fulcrum TO crossmember, and for Camber adjustment. SAME thickness shin is required for BOTH retaining bolts.
I have a PDF detailing that IF you want it.
The rest, no idea, YET, New Whisky is open, so look out.
Old Sep 13, 2025 | 04:31 AM
1A and 1B ring dim bells, as to do with the adjuster to the timing cover, for the alternator, and the steer pump.
Old Sep 15, 2025 | 12:53 PM
Grant,
Please sen me the PDF for the installation of the forked shims.
Old Sep 16, 2025 | 12:04 AM
Originally Posted by Patrick 1989 XJS
Grant,
Here ya go.
Also the steering arm shims that confuse so many.
File Type: pdf
farm-jag
General Tech Help
Sep 30, 2025 08:20 PM
Wingrider
Dec 16, 2021 04:52 PM
64etype
Apr 1, 2020 04:23 PM
Hafrod
Feb 12, 2016 09:46 AM
deejaye72
Apr 12, 2009 09:47 AM
